Question about Jenn-Air JCD2389G Side by Side Refrigerator
Is there a recall on Jenn Air Refrigerator model # JSD2695KES
Fridge and Freezer just stopped working, controls won't adjust to lower temps.
5 Suggested Answers
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: i have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: My jenn-air refrigerator and freezer temp controls
you need to unplug it and put oil in to it so that is will sorf and easy to turn .... or change the temp.adjuster key
Posted on Jan 25, 2010
allbrands
  • 600 Answers
SOURCE: Our Jenn Air top freezer
Hello, Thank You for using FixYa. I will be helping you today. It can be a fan issue, The fan in the freezer may not be working. Can you hear the fan motor running in the freezer? It may also be the damper in the fresh food section not open correct. Also if a door was left open the vent up to the fridge could be frosted up. Feel for air flow in the fresh food section by the vent.
Thank You and please rate my answer if it was helpful..
Posted on Jun 27, 2011
Jenn air JSD2695KES. Freezer is -2. Fridge side 45. Air movement is decent on freezer side Minimal on fridge side.
You may have a defrost problem starting. You can also clean your condensor coils if the are dirty it will affect the refrigerator temps sometimes.
Jul 24, 2015 | Refrigerators
Jenn-air refrigerator too cold
what are your temp control settings frrzer should be about zero and fridge side should be around 39 degrees temp. try setting it lower maybe 3 if control knob if digital check for 39 to 40.
Oct 21, 2013 | Jenn-Air JCB2285KES (21.5 cu. ft.) Side by...
My Jenn-air *** has all but quit producing cold although the freezer is still working fine. So is the light on the *** side.......any ideas.....would it be the thermostat? My husband is out of state and I...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jun 15, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air side by side refrigerator Model JCD2389GES is still making ice, food is still frozen on ice making side, but the refrigerator side is not cold, milk is souring rapidly and vegetables are turning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 09, 2009 | Jenn-Air JCD2389G Side by Side...
Why isn't our refrigerator staying cold? It is staying around 50 degrees and no lower.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works ....fridge doesnt
What is the recall for?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Dometic RM2652 Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
How to check stuff>
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 06, 2009 | Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Logo
27 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
