Question about Krups Small Appliances Espresso Machine
Coffee Not Hot Enough
We have a Kriups 324 Duothek dual carafe machine and the coffee is not hot enough when it brews. Is there any temperature adjustment that can be made to the appliance?
  • 2,039 Answers
Probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Posted on Jan 11, 2009
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Why is the coffee not hot enough
Coffee should not be hotter then 98 degrees out of the machine. I have the same problem. before I brew I fill my cup with hot water and that helped me for a hotter cup of coffee. some machines allow you to adjust temperature, eg, Krups
Dec 13, 2014 | Coffee Makers & Espresso Machines
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
Hi, I have owned that coffee maker for years.
After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
If you have to wait before you drink it, do the same. Stir it first.
Hope this has been helpful
Love that grinder!
Best Regards,
Mark
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
My bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot for up to five minutes to heat it up. This still doesnt help.
Is the coffee coming out hot enough? If you measure the coffee as it comes into the carafe, it should register at 175-185 degrees. If it doesn't, then it is a problem with the machine and needs to be replaced. If it is that temperature, then the carafe needs to be replaced. Please contact customer service with the model and date code located on the bottom of the machine. If the machine is 3 years or less it can be replaced at no cost. If over 3 years, it can be replaced at a reduced cost.
Nov 29, 2009 | Bunn B10 Coffee Maker
Bunn thermal coffee pots not keeping coffee hot
If might not be the thermal pot, it is possible it is the machine itself. If you have a candy or meat thermometer, place it in the pot as soon as the coffee has completed brewing. The temperature should be at 175-185 degrees. If it isn't, then the machine needs replaced. If the temperature is correct, then please call customer service with the model and date code to get the thermal carafe replaced. If the temp isn't correct, and it is 3 years old or less, the machine will be replaced for no cost. If it is over 3 years old, it can be replaced at a reduced price.
Jul 12, 2009 | Bunn Coffee Pots: Thermal Carafe
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
457 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
