Question about Westinghouse Used Original W4207 Remote Control
I bought a Westinghouse monitor/TV model W4207 I bought a universal remote now I CAN GET THE vcR/DVD TO WORK with it but can not get any channels even though it is hooked up to cable TV. Do I have to have the manufacturer's remote.
    Top Expert:
  • Westinghouse Master
  • 35,736 Answers
If you have cable TV, isn't there a box with its own remote?
Posted on Dec 04, 2012
5 Suggested Answers
  • 67 Answers
SOURCE: hello i need de code
go to www.manualsonline.com enter the model number of your uni-remote in the search bar, they have westinghouse items there.
Posted on Oct 17, 2010
danbusa
  • 185 Answers
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Posted on Apr 19, 2011
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
BeckiB_DISH
  • 286 Answers
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Posted on Apr 21, 2011
ercupa190
  • 12223 Answers
SOURCE: westinghouse tv remote doesn't work
1) replace new batteries with the same tipe alkaline
2) see the polarities are wrong
3) clean the contacts batteries with c. cleaner
4) retight the spring contacts batteries with l plier for better contacts
5)open the r. control clean the keypads from dirty, corrosion, oxide and bad contacts.
6) reset the code
7) try again, if the problem persist go to the repair shop TV for fix it.
God bless you
Posted on Oct 16, 2012
Remote does not work
Batteries? I replaced mine with a new RCA universal remote, works far better than the original MFG remote. Cost $15.
Mar 26, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
The remote has stoped working?
Remote testers are available (5 dollars) or you can take to Radio Shack to determine if problem is remote or set.
all sets have a remote receiver usually on front that receives the infrared signals from the remote===either the remote control or the receiver is bad.
Mar 11, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
(19 inch LCD Westinghouse tv).....Lost my remote and I can't get the video mode on. It only shows DVI and D-SUB. Also I bought a universal controller that can't change channel or view menu nor put...
Hello Madali657, you can obtain a remote by calling Westinghouse customer support team at 1-800-701-0680 and selecting the spare parts options or you can send me an email request with the model # and serial # to westytech@westinghousedigital.com and I will make sure you get a new remote for your TV.
May 24, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
Was dusting television, must have hit a button because now there's no picture. We can hear the satellite and can change the channels but there's no picture. the menu screen says no input
Simply try removing from the wall Power and and then reconnect, this should reset anything that was done.
http://www.generalmanual.com/Monitors/Westinghouse-W4207-HD-Monitor.htm
Above is your user manual this may help sort it out if removing from the power to reset doesn't work.
Aug 08, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Does any one have the code for westinghouse tv -dvd player for the r remote JR300 and for a vcr- dvd player combo{sansui progressive scan}
If you don't have a Westinghouse remote the only codes that will work for a universal is the Sony codes, if all else fails you can buy an original remote for about $15 plus shipping and handling at parts@wde.com, just make sure you write the correct model of the TV and your contact information.
Jan 17, 2010 | Jensen JR300 Remote Control
Direct tv on universal remote
For this type of problem you will need to call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for assistance with your problem. Thank you for using FixYa and have a nice day!
Apr 04, 2009 | RCA 3-Device Universal Remote with...
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse Used Original W4207 Remote Control Logo
121 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
