Question about Toshiba Portege R200-S234 PC Notebook
Toshiba portege r200 built in hdd unlock - Toshiba Portege R200-S234 PC Notebook
SOURCE: Built in HDD Password for Toshiba Portege S100-S1133
remove the rtc battery it's look like a bateery on the organizer its round and flat remove it then disconnect to remove the password
Posted on Feb 16, 2009
leecom72
  • 4806 Answers
SOURCE: Toshiba R200 aniversary edition UK -LCD replacment
Hi there.
Yes some screens are interchangeable between laptops, the best way to find out is take the screen out and take note of the serial number behind the screen and the ribbon cable connectors to see how many pins they have (some laptop screens differ) if the serial numbers correspond and the cable fits then you should be good to go.
Good luck and thanks for using FixYa!!
Posted on Mar 13, 2009
micromaster
  • 3614 Answers
SOURCE: Toshiba Portege R200 laptop service manual
If you can't find the jumper to flash the BIOS or if such jumper doesn't exist, you can remove the battery that keeps the BIOS memory alive. It's a button-size battery somewhere on the motherboard (on elder computers the battery could be a small, typically blue, cylinder soldered to the motherboard, but usually has a jumper on its side to disconnect it, otherwise you'll have to unsolder it and then solder it back). Take it away for 15-30 minutes or more, then put it back and the data contained into the BIOS memory should be volatilized. I'd suggest you to remove it for about one hour to be sure, because if you put it back when the data aren't erased yet you'll have to wait more time, as you've never removed it. If at first it doesn't work, try to remove the battery overnight.
Important note: in laptop and notebooks you don't have to remove the computer's power batteries (which would be useless), but you should open your computer and remove the CMOS battery from the motherboard.
Posted on May 30, 2009
Tech4less
  • 35 Answers
SOURCE: Toshiba Portege r200 is making whirring noises
Its problem two things. One, the fan on the heat sink or your hard drive. More than likely your hard drive.
Posted on Feb 06, 2010
  • 4 Answers
SOURCE: Beeping inside Toshiba Portege R200 laptop
change it
bay its new verson
Posted on Mar 01, 2010
NO PUEDO ENTRAR AL SETUP
Usted no esta solo! Un usuario dice "tuve que llamar al servicio al cliente de escritorio de ayuda, ya que tomo un tiempo para establecer no tan sencillo '
Se 'suspendio' pero puede conseguir obtener el apoyo de:
http://www.toshiba.co.uk/discontinued-products/portege-r200-110/
You are not alone! One user says ' had to call the customer service help desk because it took a while to set up not so straight forward'
It is 'discontinued' but you may get get support from:
Mar 05, 2014 | Toshiba Portege R200 Notebook
Internal-hdd error
you could try running chkdsk to see if that shows any errors.
go to start menu and open my computer or computer so that you can see the drives. right click on C: drive and choose properties, choose the tools tab and under error checking, click check now. make sure both boxes are ticked in the check disk window and then click start.
Mar 09, 2012 | Toshiba Portege R200-S234 PC Notebook
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
Feb 06, 2010 | Toshiba Portege R200 Notebook
Lost user manual
You can download the Portege R200 User manual from the following Toshiba Support Link
http://support1.toshiba-tro.de/tedd-files2/0/userman-en-20090129080445.zip
Nov 12, 2009 | Toshiba Portege R200-S234 PC Notebook
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Mar 18, 2009 | Toshiba Portege R200 Notebook
Hi there.
Mar 13, 2009 | Toshiba Portege R200 Notebook
Locked toshiba
I'm sorry but I can not help you unlock this you will have to bring it to a service center or call toshiba to unlock it.
Mar 02, 2009 | Microsoft Windows XP Professional With...
Feb 16, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege R200-S234 PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
