Question about Ovens
F2E1 the oven beeped and went off. I tried to turn it on again and it wouldn't. After it cooled I pressed Cancel. I had to reset the clock and everything seemed to correct itself. I was scared as its before Christmas and I really dont want to buy another stove right now. I did have a pizza stone in the oven and a pan on the floor of the oven so perhaps I helped caused this problem. I will not put these back. The question is, IS this a problem that I Should have looked into or is it taken care of now?
    Top Expert:
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
SOURCE: Error Code F8
Try http://www.applianceaid.com/fault_codes.html
Posted on Jan 06, 2008
SOURCE: magic chef electric oven...went to
How do I replace the oven heating element in a Magic Chef oven?
Posted on Dec 31, 2008
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
SOURCE: whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Posted on Dec 25, 2009
espressonist
  • 1711 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Posted on Aug 20, 2011
Frigidaire oven fpcf3091lf eo90 code keeps lighting up and beeping after the power went out.how do I get it to stop I have unplugged it and waited 5 min. But will come back.
http://manuals.frigidaire.com/prodinfo_pdf/Specsheets/FPCF3091L_1011_EN.pdf
Electronic control has detected a fault or error condition. Press CANCEL to clear the display & stop beeping. Try the selected feature again. If the E or F error code repeats, remove power from appliance, wait 5 minutes and then repower appliance. Try the selected feature again. If the fault recurs, record the fault or error code and call for service.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902218en.pdf
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316904423.pdf
May 30, 2015 | Frigidaire Ovens
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
I have a bosch oven and the power in my house went out during a storm and when it came back my oven started beeping and has not stopped since... what do i do???
Hello- You may have done this already, to save your sanity, but I would turn off the breaker for a few minutes. It is most likely beeping to tell you there was a power failure (as if you didn't notice). Once it is back on you will need to reset the clock, it may not stop beeping until you do this or press cancel. If this does not remedy the beeping there may have been a power surge that caused damage to the control board in which case you should call a Tech out to have a look. Good luck, best regards.
Sep 28, 2010 | Ovens
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
JennAir 27
try unplugging the range for 30 seconds and see if it resets
Apr 01, 2008 | Ovens
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
