Question about NAD C521 CD Player
Drawer opens when the player is switched on
When i switch the cd player on (without a disc) it reads for a cd, for about ten flashes of the digits, then opens the tray. If i insert a cd then shut the drawer it does the same thing- just ejects the tray. Read elsewhere that it could be the drawer belt, though the drawer seems to be shutting fully.
Any ideas or comments greatly appreciated. Regards, Marc
  • marcwithac78 Jan 12, 2009
    Many thanks, problem solved!
  • 165 Answers
Hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Posted on Jan 11, 2009
Yamaha CRX-330 CD drawer won't open
I had the same problem. It opened when I gave the reciever a slight lift and let it dropp, after I pressed the Reject Button. It's not a solution but at least it's open.
Jan 10, 2014 | Yamaha CRX-330 CD receiver
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
Sony cdp 350 compact disc player will not spin to read disc once drawer if closed, it will buzz a little then drawer will open. If disc is in player and using a screw driver on bottom to manually open and...
There's never been a better time to switch to Juniper. Right now, you can reap the rewards of being a part of the new network - in just a few days. Juniper EX Series switches are standards based, so implementing them with your existing network is easy and seamless. And the benefits are huge. At least a 30% reduction in capital expenditures. Increased efficiency. Less energy consumed. And a network that's easier to maintain and operate.
We'll work with you to find the most cost-effective solution for your specific needs. In return, you'll get a fully automated solution that readies your network for anything that lies ahead. You'll get your new switches in a couple of days - not in 6-8 weeks. And we'll be ready to provide any support you and your employees might need. Your network will be more streamlined, more efficient, and more cost-effective.
Dec 01, 2010 | Sony Audio Players & Recorders
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Cd player drawer will not stay engaged when a disc is inserted
By not engaged i'm assuming you mean that the disc draw closes then opens again almost immediatley. This would indicate that the disc draw limit switch is not being activated by the draw or the switch has failed.
This is usualy a small sub-miniature micro switch activated by the draw itself, Sometimes a very light spray of switch cleaner into the micro switch will effect a cure. The switch gets a fairly hard life so it is more advisable to replace the switch.
Mar 16, 2010 | Sony Audio Players & Recorders
DOOR KEEPS OPENING instead of playing
Hi. there is a tiny limit switch that regulates the actual CD platform drawer(The part where you lay down the CD). this switch if faulty. it is designed to shut of the load motor when the CD tray is fully inside the unit.
this limit switch must be replaced. this is a job for a qualified Yamaha service tech. contact Yamaha for this repair.
Jul 29, 2009 | Yamaha CDC-585 5-Disc CD Changer
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Lg rc797t dvd drawer will not close consistently
I have a Compaq Presario desktop running XP Media Center. The DVD tray would open on power up, and kept openinig when pushed shut.
I discovered that the tray would frequently remain closed when I held open the flap (the flap with the open button). A few days after discovering this, I got to add some more tracks to my MP3 player - I only mention this intermediate stage in case it is material in curing the problem, as the next thing that happened was a power failure whilst the PC was on. Since then, the CD/DVD drive has behaved perfectly. I did have a temporary problem with AVG INternet Security being unable to load the necessary DLLs to run correctly in MS Outlook 2003, even complaining of a corrupt installation, but this dissappeared after a proper restart and AVG update.
So,
Compaq users: try holding the flap open when you attempt to close the tray.
Generally: with PC running and all applications closed, switch the power off at the wall socket.
HTH
Roger
Shaftesbury (UK)
Jan 25, 2009 | Computers & Internet
NAD C521 CD Player Logo
296 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
