Question about Samsung Vacuums
Terrible smell from my Samsung Airtrack 2000w vacuum cleaner
4 Suggested Answers
SOURCE: vacuum smells
In addition to vinegar, baking soda (sodium bicarbonate) is also an excellent remedy for many odour problems.
Try generously sprinkling baking soda on a rug you wish to clean, and afterwards, vacuum up the spot.
Rugs, and dirt may be broomed beforehand, and you may want to spread the soda over a large enough area to avoid having a small "clean spot".
Repeat as necessary, and buy the bigger boxes of baking/washing soda. It has many more great uses that you can discover.
Posted on Apr 04, 2008
reddevil6
  • 1673 Answers
SOURCE: bosch hepa 2000w vacuum -
I it is an electrical smell, then you have a bad motor, if a rubber smell, you may have a bad belt and/or brush roll.
Posted on May 13, 2008
SOURCE: Vacuum cleaner smells bad
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=732502
Generic problem for all Vacuums
Posted by WhyAge on Jul 02, 2008
My Vacuum cleaner smells bad. What can I do to stop that?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Depending on the brand name and model # you should do a few things, try changing the bag and or change or clean the filter depending on what type of vacuum you have, a dirt cup model or a bag system. The vacuum cleaner dealers have Vacuum crystals that can be sprinkled down on the carpet and then you can pup the crystals from the carpet with your vacuum. If not I suggest that you take it in for a good and general cleaning – a lot of times the dirt and dust get built up under the hood and just sits there – especially if you have pets and it is a hard smell to get rid of unless you have it serviced or cleaned. If you have any questions, please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
How do I load the vacuum bag in the Electrolux power plus 2000w
If your Electrolux vacuum cleaner uses paper bags, the instructions should be printed on the bag.
Dec 03, 2014 | Electrolux Vacuums
My 2000W hepa Black and Decker Vacuum cleaner
the power head might be binding or possibly the belt slipping
Sep 17, 2013 | Black & Decker Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Hi, I have Pnasonic Vacuum cleaner MC-7650 -2000W,while working machine stops its own.I tried all the way ,all in vain
If it operates less than 15 minutes suspect the filter is blocked and that will cause the motor to heat triggering shut off.
l have seen this and the filter may be washable or not.
Dec 04, 2012 | Panasonic Vacuums
My samsung air track 2000W makes a really loud noise after 5 seconds of vacuuming. Sounds like its overheating but Ive cleaned all the filters so don't know wat is wrong!
I have the same vacuum. I cleaned the blue filter under the cylinder. Took it outside and hit it for about 2 mins to get much of the dust out, then washed it and left it to dry as it said in the instruction booklet. A copy of the instruction booklet is here: http://downloadcenter.samsung.com/content/UM/200903/20090304083344937/DJ68-00387A_EN_0.5.pdf
May 07, 2011 | Samsung Vacuums
Blown vacuum fuse?
Sounds like you got a clog in the hose, which depleted the suction. After getting clogged the motor was working overtime and burned up. If your vacuum is still under warranty you should bring it to a warranty repair center to be fixed. Changing a motor in a vacuum is almost as expensive as buying a new vacuum cleaner. So if your vacuum is out of warranty I think you should probably buy a new one.
Oct 09, 2009 | Vacuums
Our dog urinated on the machine. We cleaned both filters & plastic areas. Some might have gotten into the motor housing since it still smells terribly when turned on. Please advise
Place a Febreze sheet in the canister/dirt bin where the dirt collects. Let it spin around in there whilst you're using the machine. The fragrance will be spread throughout the vacuum cleaner. If that still doesn't work, you can always replace your filter - just call the Dyson Helpline and biuy a new one.
Jul 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bosch hepa 2000w vacuum - burning smell coming from appliance
May 12, 2008 | Vacuums
Vacuums Logo
108 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
