Question about SLY electronics Audio Players & Recorders
I need a manual for operation of my sly electronics SLV202g
P6N SLI (MSI 7350) v1.0 OCZ RevoDrive 3
Hello you can download a manual from here:
http://www.msi.com/product/mb/P6N-SLI.html#/?div=Manual
Unzip the file before you can read the content.
And you need adobe reader.
More about OCZ here:
http://www.ocztechnology.com/ocz-revodrive-3-x2-pci-express-ssd.html
Good luck
Nov 23, 2012 | Nvidia Bios Chip:msi P6ngm2-l P6n Sli...
Need manual for A8n-sli MoBo
Here you go ftp://ftp.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2068_a8n-sli.pdf
May 19, 2011 | Computers & Internet
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
SLY Electronics Model # sl314cm/Accessing music
It all depends on how you put it onto the player. Go to my computer, SLY, AUDIO, and then copy paste the music you want onto it. If you're downloading the musice off the internet from a place like spiralfrog.com it won't work because the music has no appropiate license.
Mar 26, 2009 | Audio Players & Recorders
Graphics card no display, not recognised
Hi DarkPredUK.
You need to check you're bios. (See below).
The PCI-E card (Single video card) must be placed into slot, PCIEX16_1 as shown on page 2-3 & 2-18 in you're user manual. The bios must be set correctly as seen on page 4-26 to PCI-E first. You must have two PCI-E cards installed to run SLI mode. (They must be exactly the same graphic cards).
Asus M2N-E SLI main web site/drivers, manual ect.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good luck DarkPredUK.
Need more info? Post it here or click the Ask Me.
Mike
Jul 11, 2008 | Computers & Internet
SLI Video Cards
Enter you're bios & open you're manual to page 4-32. Set you're
configuration to dual video card. Use the AL software to tweak you're settings in windows. If you find this not helpful than please call Asus tech at: 1-812-282-2787, M-F 8:00AM-5:00PM EST. Unlike other companies you will not be on the phone very long. Please have the S/N of the board handy. This is located on the board, on the LTP port (White sitcker).
Good Luck!
Mike
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Need help
u need manual for dis motherboard? MSI K8N Neo4 Platinum PCI-E
Nov 12, 2007 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
Need wiring harness guide for asus p5n32-sli deluxe motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI%20Deluxe
You can get all the files you need here.
Download and print only the parts of the manual you need or it will be almost a whole stack of paper.
Good luck with this mobo.
I've had nothing but prob;lems with it.
I'm going back to my ecs that I know works.
I suggest you search "problems with p5n32-sli".
Oct 18, 2007 | ASUS P5N32-SLI Deluxe Motherboard
27 people viewed this question
Top SLY electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SLY electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
