Kleenmaid washer model - LWK24NW-3050, require parts list &/or workshop manual thankyou.
Serial number is 0703 017 020. Need to overhaul washing machine. Need a parts list information sheet or a workshop manual please.
mastatech
  • 478 Answers
SOURCE: remove agitator washing machine
Pull off fabric softener dispenser, then there will be a screw holding agitator in middle you will need a rachet, socket, and at least a 10" extension. Lossen and remove screw and pull from bottum of agitator.
Posted on Jul 05, 2010
  • 1937 Answers
SOURCE: Kenmore washer model #110.29842991 will not drain.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-110.29842991/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Aug 30, 2010
SOURCE: KleenMaid Washing Machine shop manuals/repair instructions
There are manuals available but these only tell you about the parts of the machine and the different cycles etc. Its a workshop manual that you need and these are not discussed anywhere on the net, Im not sure these were ever produced.
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: How to remove agitator from a Kleenmaid washer
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
ginko
  • 19396 Answers
SOURCE: Our Washing Machine will not spin out , on any
Hi.
Even if I am not referring to single parts numbers, the comment below is not just an educated guess. I checked the schematics for your commercial top loader. You will find all parts I am referring to listed in the page linked at the bottom of my comment.
The belt worn or broken will not cause no spin, the machine will not spin and not agitate if the belt is broken.
About the motor. A defective motor may cause washer not spinning, but the fault is not very common.
In some uncommon case the problem can be the main control unit (CCU), but that is also unusual.
There are parts that fail quite more commonly, and that are typically causing no spin.
When machine drains completely but the cycle does not advance to spin it is usually either drain problem, door latch or pressure switch. Even if the machine is draining, the drain filter must also be tested.
Before getting into Spin, the machine control performs a double check on door latch. A defective door lock system can cause no spin. The door lock can be tested by jumping the door lock microswitch contacts.
Before advancing to spin, the central control unit checks also the drain status, using the pressure switch. The pressure switch detects water level and 'gives the OK' to advance after drain is complete. The pressure switch is difficult to test (testing is done reading impedance with tub full and empty). The pressure switch is however a not-too-expensive part, and it is usually replaced without testing.
Resuming:
Have a look at the drain hose and drain filter to ensure that there is no blockage. Check hoses to drain pump and ensure that the pump is working.
Check the lid switch. This can be tested by running a cycle with its contacts jumped.
Replace the pressure switch, that is most likely the problem.
Test the variable speed motor and test the central control unit if the above did not fix the problem.
Here all parts and diagrams for Kleenmaid washers.
Regards.
Ginko.
Posted on Nov 18, 2010
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Kleenmaid LWK74AW-3050. How do I clean the pipe/hose from the back of the washing machine to the tub??
Inlet hoses connected To washer have a screen trap in them disconnect and clean.
Oct 22, 2015 | Washing Machines
Kleenmaid
You should be able to download the instructions from this site.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/WM/kleenmaid/39237R4_LWK23_24_Op_Inst.pdf
In case you have a specific problem with the washer please describe in the comment section and the right expert on this site should be able to assess it.
Sep 19, 2014 | Washing Machines
Yamaha gladiator chain sprocket damaged within 6 months why
Repair manuals (also known as Service Manuals or Workshop Manuals) contain the information you need to perform routine maintenance and repairs. These manuals generally include periodic maintenance charts, step by step repair instructions, troubleshooting information and overhaul procedures. Wiring diagrams are usually included. If you need to overhaul an engine for example, a repair manual will guide you through the process. Repair manuals are used by the service departments of your local dealership.
Owners Manuals
Owners manuals (also known as Operator Manuals) include the information you need to understand how to safely operate the related piece of equipment. These manuals also include very basic information on maintenance but do not include detailed overhaul procedures like a service manual. Owners manuals are usually included by the dealership when you purchase a new vehicle.
Parts Manuals
Parts manuals include detailed schematics of every major system that makes up your vehicle. The drawings include individual parts as well as parts groupings. Every parts schematic has a corresponding page that lists the part number, quantity and description of the part. These manuals are helpful for understanding how an assembly goes together and for ordering parts.
Repair Manuals Online
Aug 30, 2014 | Motorcycles
Kleenmaid G10-FF6 Manual
Hi Andrew,
I tried looking for the manual but couldn't find it. Here's what I found:_____________________Urgent Information for Kleenmaid CustomersKLEENMAID LIQUIDATION NOTICEThe Kleenmaid Group was placed into liquidation in May 2009.
Kleenmaid Customer Solutions, the former Kleenmaid appliance service business was acquired by Aussie Whitegoods Rescue. For service, spare parts or sales on replacement product please phone or email our contact centre.
For further information relating to the liquidation of the Kleenmaid Group, please visit the Deloitte website www.deloitte.com.au or email kleenmaid@deloitte.com.au
For Service, Sales & Spare Parts you may call Aussie Whitegoods Rescue at Phone # 1300 652 100. Trading Hours 8.30am - 5.30pm Mon - Fri EST
They might be able to help you with the manual for your oven.
I hope this helps.
Dec 05, 2011 | Ovens
Have a kleenmaid front loader washing machine KLF 1600;it needs a bearing kit[2 bearings & seal]???for main drum and also a belt MIG OPTIBELT 6EPJ1260 code 111622 or GATES 6EPJ 1260 code...
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 11, 2011 | Washing Machines
Kleenmaid kfl 1506 manual required
You can view and download your manual in PDF format at this address.
http://www.kleenmaid-appliances.com.au/use&care/WM/kleenmaid/KFL1506_660448en.pdf
just copy and paste it into your address bar.
Apr 30, 2011 | Washing Machines
I have a Maytag Neptune Model #: MAH5500BWW Serial #: 74920520ZZ The door refuses to close. If I slam it a few times, it eventually closes, locks, and it washes fine. I was considering replacing the lock...
If definitely sounds like you have a door latch problem. Slamming the door repeatedly, however, is probably doing more harm than good. You may be able to get the door to work intermittently for now, but eventually, the lock will stop working altogether.
You are correct. The part numbers ARE based on the Serial Number (series) when it comes to Maytag appliances. If a series is listed next to a part (series 10, for example), the part applies to all appliances that have a serial number beginning with "10" or higher. If an additional series is listed (20, for example), the part applies to all appliance that have a serial number beginning with "20" and higher.
EXAMPLE:
Series 10 (serial numbers beginning with "10 to "19")
Series 20 (serial numbers beginning with "20" to "29")
Series 30 (serial numbers beginning with "30 to "39")
So...using YOUR appliance serial number for this example, if you had a part that had several series listings, you would use the one that matches nearest to your serial number. Say, for example you had a door latch that had three different versions (series 10, 20 and 30). You would use series 30, as the number is the closest to the beginning two digits in your serial number. If your serial number began with "19", for example, you would use series "10", because the first two digits in your serial number do not exceed "20". If only one series number is listed, or if no series number is listed, it applies to ALL washers under that particular model number regardless of serial number. Confused now? So am I.
Based on the information you've provided, the part number for a replacement latch assembly for your washer is: 22004435.
You can purchase replacement parts at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also inclide helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. There are also helpful wiring diagrams included on some sites. Prices vary, so shop and compare.
NOTE: If your model number is not listed on some sites, use the part number from the Sears site as your search criteria. Sometimes certain model numbers do not always appear on parts websites (due to the appliance being too old, recently added model, etc.), but the part numbers generally will, because many parts are interchangeable between model numbers. If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Oct 12, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
