Question about Casio FX-115ES Scientific Calculator
How to convet binary to decimal in casio fx 85 ms
SOURCE: casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Posted on Jun 09, 2009
  • 8068 Answers
SOURCE: how do i display decimals on casio fx 115es
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
Posted on Aug 17, 2009
  • 47 Answers
SOURCE: how to do binary,hex BCD and decimal on casio
to convert between bases, go to keyboard, then cat(alog) and press B to scroll down to baseConvert(
syntax: baseConvert(value to change, original base, new base)
e.g. to convert 1100 from binary to decimal
baseConvert(1100,2,10)
Posted on Feb 18, 2010
  • 102366 Answers
SOURCE: i want casio fx-991es result
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Posted on Oct 04, 2010
How can i convert decimal to binary number in casio fx 82ms calculator?
This gentleman explains it very well. The trick seems to be to enter the number and then hit the equals sign, and then do the conversion.
Good luck,
Paul
Decimal to Binary and Hexadecimal conversions using casio fx 991MS HYONKOWS
Dec 20, 2016 | Casio Office Equipment & Supplies
How to change a decimal value to binary number in fx-85GT PLUS ? Thanks!!
Let's do the preocess so it will work on any calculator.
As an example, convert 68 from decimal to binary.
The decimal columns are 10^0, 10^1, 10^2, 10^3, etc.
The binary columns are 2^0, 2^1, 2^2, 2^3, etc.
Flipping to the normal left to right, we get 2^6, 2^5, 2^4, 2^3, 2^2, 2^1, 2^0.
64 32 16 8 4 2 1
We divide our number, 68, by 64, and get 1 with a remainder of 4. We next divide our remainder by 32, 16, 8, and finally 4, where we get 1 with no reminder.
In binary, this works out to 1000100. To check, we multiply the ones by the respective column values and get 64 + 4 = 68.
Good luck.
Paul
Feb 28, 2016 | Casio FX-85GT Plus Scientific Calculator...
How to convert a dinary number to a binary number using a casio fx-82MS calculator
Dinary? Never heard that one before. What is a dinary number? Anyway your calculator cannot perform the operations. The Casios can work in Binary (base 2), Octal (base 8), Decimal (base 10) and Hexadecimal (base 16). Some Sharps can do calculations in base 5 (pental).
Feb 19, 2013 | Office Equipment & Supplies
Converting from BASE-N to Decimal
If you want to convert from another base to decimal, press MODE 4 to enter the BASE-N mode, select the initial base (binary, octal, or hexadecimal), enter the number, then switch to decimal to see the value in decimal.
If you want to exit the BASE-N mode, press MODE 1 to switch to the computational model or MODE 2 for complex mode.
Oct 04, 2011 | Casio FX-115ES Scientific Calculator
How to get my fx-300es into decimal mode
I am not sure about what you want.
  1. Decimal results or fraction/radicals?
  2. Decimal numeration as opposed to binary/octal/hexadecimal?
For the first case, set Input/Output IO mode to LineIO (SHIFT MODE 2:LineIO)
For the second case set Computational mode to COMP etc, but NOT to BASE-N
May 23, 2011 | Casio fx-300ES Calculator
How to get from dec. to binary
If you're already in decimal mode, press SHIFT BIN to switch to binary mode.
To convert a number from decimal to binary, press MODE 4 to switch to BASE-N mode. You'll find yourself in decimal mode. Enter the number to convert, press =, then press SHIFT [BIN] (the log key) and see the number in binary. To convert another number, press SHIFT [DEC] to return to decimal, enter the number, press =, then press SHIFT [BIN]. An analogous process works for hexadecimal and octal as well.
To return to "normal" use, press MODE 1 for COMP mode or MODE 2 for complex mode.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
How do you convert decimal numbers into binary?
Press MODE 4 to enter the BASE-N mode. Type in the decimal number, then press BIN to convert to binary. Press DEC to switch back to decimal for the next conversion.
You're limited to numbers in the range [-32768...32767] in binary. You can extend the range if you convert to octal or hexadecimal and then mentally convert each digit to three or four bits.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
When I square .05 I keep getting 2.5x10-3 is there any why to get it to read .0025 instead?
Change Mode to Norm 2 in case of Casio fx 82/83/85/270/300/350 MS or Choose fix.
Jul 14, 2009 | Casio FX-115ES Scientific Calculator
Binary conversion
In the FX-300Ms manual, the same for the FX-82MS, there is no way to use base-n (binary, octal, hexadecimal) calculations.
Sorry.
Feb 22, 2009 | Casio FX-300MS Calculator
Convert to/from Decimal/Binary
Press MODE 4 to enter the BASE-N mode. If the display doesn't say Dec, press SHIFT DEC (the x^2 key) to set base 10. Enter the number to convert. Press SHIFT BIN (the log key) to switch to base 2.
Each time you switch the base the current value is redisplayed in that new base.
Feb 07, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
192 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
