Question about Ovens
Replace oven bottom element for chef ebc5231W#36
How do you remove the element to replace, we heard a pop noise and it stopped working no heat at all, the stove top and grill still work fine.
  • 27 Answers
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Posted on Nov 01, 2007
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
    I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
    318022002 is the part number for the relay board with transformer
    318022001 is the part number for the relay board without transformer
    Yes the one without the transformer is more expensive for some reason.
    The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
    To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
    NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
    Posted on May 13, 2009
    While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
    The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
    Jan 18, 2017 | Ovens
    Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
    This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
    Sep 26, 2015 | Hotpoint Ovens
    My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
    The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
    Dec 26, 2014 | Magic Chef Ovens
    Oven made pop noise now won t heat
    It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
    Feb 20, 2014 | Ovens
    CHEF EBC5231W*53 OVEN.overcooks food underneath but undercooks on top side.any tips would be grateful
    Did you per chance put the food on a plate that pretty much is as big as the oven? If you did, you trapped all the heat from the baking element under the food. Please check that first.
    Aug 10, 2011 | Ovens
    Oven was operating. we heard a noise or pop and power shut off in oven
    what type of oven is it? possibly a blown fuse internally causing the pop you heard or the heating element my have blown....
    Dec 27, 2010 | Ovens
    Heard a pop/bang and now no heat
    Sounds like the oven element has blown.
    To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
    Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
    I lifted up the heating element on the bottom on the oven to clean up a spill, I heard a pop and the power to the oven went out.
    you shorted out the leads on the oven case when you lifted the element, even though the element is off there is power to one side of the incoming element
    Oct 04, 2009 | Ovens
    Oven will not heat
    Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
    Plz let me know how you get on.Thanks.
    Jan 03, 2009 | GE JKP15 Electric Single Oven
    No heat when i switch oven on
    There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
    If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
    Remove and replace.
    If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
    Plz rate my solution.
    thanks,
    Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
    Ovens Logo
    41 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
