Question about Samsung Bn59-01041a Remote Control
How to program samsung Bn59-01041a remote to run direct tv DVR
4 Suggested Answers
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
  • 11 Answers
SOURCE: Samsung (RS105N) Remote Control
Found the user manual here
http://www.directv.com/learn/pdf/System_Manuals/Samsung/Samsung_SIR300-310W.PDF
Posted on Jan 03, 2009
gopakumarg43
  • 74459 Answers
SOURCE: Need codes and directions to program my aa59-0322 remote to my Samsung tv
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Apr 01, 2012
I have direct tv dvr my remote wont work,but remote works on my other recivers,has the ir gone bad and can it be fixed
It's possible that the IR receiver in the DVR has failed. It's unlikely to be the remote as it works with other devices. If the remote was working with the DVR before, then in most cases the problem can be corrected by resetting the DVR as follows:
Press the RED RESET BUTTON behind the access card panel on the front of the DVR. Wait for the program guide information to update then try the remote again.
Try this and post back if you need further assistance.
Regards,
BElectric
Dec 07, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
Tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
Directv remote increases volume slowly
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Feb 13, 2009 | Samsung TV Remote Control
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Dec 13, 2008 | Samsung LN32A330 32 in. LCD TV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Samsung Bn59-01041a Remote Control Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
