Question about Uniden Lands Phones
Uniden phone dect 1035 series intercom not working
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
  • 68 Answers
SOURCE: INTERCOM
you need to have all the phones linked to the same wiring. for example, i just got mine working after working on it for some time. i had 2 of my phones hooked directly into my FIOS box and the other 2 were hooked into a remote location of the building. even though my thinking says they should be able to talk to one another, they couldnt. they have to be completely wired to the same wiring system with no interuptions so they can find each other in the network. then to use the intercom system, all you have to do is press 1-16 on your speed dial to reach out to the desired location
Posted on Aug 18, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
Intercom for uniden dect 6 phone
Since you declined to specify the model of your Uniden DECT 6.0 phone, please select it from the list beginning at http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl to download a copy of the manual.
Apr 21, 2014 | Lands Phones
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Use of intercom
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here to download a copy of the manual.
Jan 29, 2012 | Uniden DECT 6.0 Cordless Phone ID
How do I use the intercom ?
Since you declined to specify the model of your Uniden DECT 6.0 telephone, please select it from the list beginning here to download a copy of the manual.
Dec 03, 2011 | Uniden DECT 6.0 Cordless Telephone...
How does the intercom work on my Uniden D!^*) cordles phone?
That depends on the model. Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
If you need further assistance, feel free to reply to this post but please specify the model.
Sep 04, 2011 | Uniden DECT 6.0 Cordless Telephone...
Request proceedure to use Intercom on Uniden Dect 6.0
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
to download the manual.
May 25, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I work intercom?
What model Uniden DECT 6.0 system?
Oct 03, 2009 | Uniden DECT 6.0 Cordless Telephone...
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
Intercom
What model Uniden DECT 6.0 phone?
May 17, 2008 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
