Question about Refrigerators
Won't cool down 72 bottle wine fridge prima
Green and red lights at back internally are on but fridge digitally reading 29 degrees
  • 3 Answers
SOURCE: wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Posted on Feb 01, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
SOURCE: Both zones of the wine
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the wine cooler and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Take care.
Posted on Oct 22, 2010
  • 11800 Answers
SOURCE: we have a 32 bottle
In that case the refrigeration from the left side is not operational on your cooler. In this model the thermoelectric system is used - the cooling is done thru the Peltier effect, not with a compressor. Because of that when the cooling element fails it must be replaced in its entirety, it can't be repaired.
This is a big job that involver the dismantling of the entire unit. Make arrangements to relocate the reds and call Vinotemp at 1.800.777.8466 - they will guide you to the nearest authorised repair shop.
Posted on Nov 09, 2010
  • 51 Answers
SOURCE: I have a 2007 GE
check compressure,thermostate relay n olp
Posted on Dec 01, 2010
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
My GE Profile Wine Center stopped cooling
Switch off, leave 5 mins then switch on again. Check display again.
Apr 22, 2012 | GE Profile FreeStanding Deluxe 29 Bottle...
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
The Wine Cooler Won't cool, the internal thermostat reads 39 degrees, but the actual inside temp is close to 70 degrees. The unit is set at 59 degrees! Sometimes I can unplug it, the plug it back in and...
Order a new control board if it is working after you unplug it it's because the control board is being reset. You can contact the manufacturer and purchase a control board directly from them .
Feb 02, 2018 | Avanti WC5100BG Wine Cooler
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
