I have canon gp225 and showing code E100
Solution for error code E100
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
Cogz
  • 1326 Answers
SOURCE: canon gp225 showing error e803
What error code is showing on the display sceen " Exxxx" it could be a bad laser unit or a bad polygon mirror ass'y.
Posted on Jan 30, 2008
  • 3 Answers
SOURCE: ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Posted on Feb 07, 2008
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 1126 Answers
SOURCE: canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
Posted on Jun 03, 2009
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
Canon gp225 with error code e0007-01 reset it but came back again
I'm not sure what a gp225 is, but the error code E007 deals with the fusing unit. It means that the fuser film can not find Home Postion. Basicly the film has moved out of place or the film is damaged and moved out of hp. Basicly,to solve the problem the fuser film needs to be replaced. Good Luck
Aug 22, 2010 | Canon Office Equipment & Supplies
Canon D340 error
Check that all the doors are shut. If that does work unplug the printer and the E100 error code should stop.
Aug 22, 2009 | Canon imageCLASS D320 Digital Copier
Canon ir5070 i have an error code e100-00001 what does this mean
E100 code
May 16, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Mar 26, 2009 | Canon Office Equipment & Supplies
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
I have an error code on my printer Error Code: E100 0000 E100 0001 it is a canon LBP5000
Well im having the same issue E100 error on my xbox one as it was never update till the other day i was thinking is it possible if the nand dumpable and get the keys or signature from it and replace it with a working nand i know it still works cos i able to do the recovery mode with the offline update dianogtic from microsoft but still error E100 after reset
For more help visit cbr tech solutions
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon gp225 showing error e803
Jan 29, 2008 | Canon imageRUNNER 8500 Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
42 people viewed this question
k24674
