Hobby Zone Champ RTF Logo
A
Anonymous Posted on Dec 02, 2012
Hobby Zone Champ RTF receiver not working.
Red light inside the plane is always blinking - did everything in the manual it said to. When I plug in the battery I can't see a glowing white light inside like it says. Transmitter is not doing anything - tried re-binding it to the plane and it didn't work. Please help.
2 Related Answers
Anonymous
  • Posted on Mar 03, 2011
SOURCE: I have a brand new Hobby Zone Champ RTF. For
I have the same problem with my champ. Rudder loses control intermittently. If I open it and flick the gear a little it sometimes responds. Any solution yet?
Anonymous
  • 1672 Answers
  • Posted on Sep 21, 2011
SOURCE: Got my brand new hobby
Remote transmitter got the problem.
If that is brand new it must have a warranty, return it to the store you bought it and test flight it in front of you before you get back home.
Hope that helps.
Repair hobbyzone champ esc
Bill, many times working on printed circuit boards can be challenging and rewarding; but often times due to over heating or poor soldier joints; the boards resistance factors cancel out the benefits of repairs. So; you waste time and materials. Just suck it up and wait until you can afford a new board and get peace of mind.
1helpful
3answers
Garage door light blinks but doesn't stay on
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
How do I replace the motor for the hobbyzone cub trainer? do I need to braze/solder the connections? How do I break the current connections?
there are some motor mounts offered for super cub which will fit exactly the holes on the nose of the plane just google it. There is a kit offered on ebay with esc and receiver. I believe 1000 kv would be enough for the plane especially with the floats it might need more power although the bigger propeller that comes with the floats would be sufficient. Personally I would change the motor only if necessary, although my receiver broke and I think i will change everything on the inside. hope to have answered your questions partly
2answers
Got my brand new hobby zone champ yesterday and it will not work, charged up the battery instailed the AA batteries into controler. turn radio on red light comes on instail battery on the air plane, you...
Hope that helps.
3helpful
I have a brand new Hobby Zone Champ RTF. For awhile, it will do fine. Then, all at once the rudder control stops working. All other parts of the plane are fine. Then a few minutes later it can be fine....
The plane stopped responding to commands from the transmitter. i have replaced transmitter batteries.
Make sure the battery for the receiver (located inside the plane) is fully charged as well.
Acquiring Hobby Zone Cub for simulator
The FMS SuperCup.par that comes with FMS is the closest to what you want.
Top Hobby Zone Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Hobby Zone Toy Expert? Answer questions, earn points and help others
