Question about GE Profile Spacemaker Over-the-Range Microwave
Replace fuse on ge spacemaker jvm3670wf001 - GE Profile Spacemaker Over-the-Range Microwave
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: GE spacemaker otr microwave - place of fuse - how
Hello there
  1. Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  2. Step 2 remove the screws that are on the very edge of the back of the microwave on both sides and there are 4 or 6 screws under the bottom of the unit
  3. Step 3 remove the cover usually it will slide out towards the back
  4. You may have to use a small flat tip screwdriver to get it to start to move
  5. Step 4 If you look towards the front on the sides youshould see sonme wires and a circuit board the fuse will be on this board
  6. Remove the bad fuse . Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component
  7. . Install the new fuse and than before you put the cover back on test it out it should now work if so put everything back together.
  8. If it dosent you probably have a part on the circuit board that has blown in that caste you may want to bring it to a a repair shop and get a quote on how much it would be to fix it.
  9. Sometimes the repairs can be more than what you paid for the microwave so be carefull here ok?
  10. I hope that this has been very helpful for you
  11. Best regards Michael
Posted on Nov 13, 2009
beltronic205
  • 1456 Answers
SOURCE: GE Spacemaker Microwave is not heating, replaced
Check thermal fuse cut out gone..
Posted on Apr 06, 2010
  • 93 Answers
SOURCE: how to remove ge spacemaker 1400?
make sure you check the diode first its cheaper and maybe worth the fix if its a magnatron throw microwave away
Posted on Nov 15, 2011
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker 1800 microwave looks and sounds as if it's heating, but no heat is generated when turned on. Is it repairable, and if so, how?
(((The fuse is located inside the unit along side the magnetron)))
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
Runs, but doesn't heat food
Hi, i recommend checking the fuse. its located on the noise filter, which is connected to the air guide. if this fuse is good, replace the magnetron tube assembly.
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
yes there is. the fuse should be located behind the vent grill on the right side above the control panel. there may be a metal "grate" covering the access to it
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
