Question about Canon PIXMA Office Equipment & Supplies
Canon Pixma mg5250 printer with B200 error Code
cns assoc
  • 677 Answers
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Posted on Nov 07, 2009
SOURCE: error b200, green and orange lamp flash
orange light blinking
Posted on Dec 29, 2009
  • 22 Answers
SOURCE: Canon PIXMA MP620 getting error code B200
Hi, This error is related to the Print head of your printer. I recommend getting in contact with Canon to activate the warranty (if it's still under warranty) or getting it replaced. They usually are not expensive and may very well be cheaper than a new printer. Do you have their number?
Hope i was of any help. If so, please rate me. Thank you.
Pcsimples
Posted on Mar 14, 2011
  • 310 Answers
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Posted on Mar 03, 2008
SOURCE: CANON PIXMA iP3300
1. turn off printer
2. Hold down resume, dont realase and press power button
3. realase resume button, now press twice resume button but dont realase power button
4. realase all.
5.now press twice again resume button and plug off power cable
6. turn on printer with plugin power cable
7. your printer will reset.
iff not working, you must chek pointing contact in head printer, use some claener with cottonbuds to clear the contact.
may you sukses!!!
Posted on Dec 19, 2008
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Jun 05, 2013 | Microsoft Windows 7 Ultimate for PC
Canon pixma mx870 error B200
how to repair b200 error code on canon MX870 printer?
Sep 20, 2012 | Canon PIXMA MX870 Wireless Office...
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
Aug 17, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
B200
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
Canon Printer Pixma MP540 with error code B200 - what can I do? Thank you for your support. Arthur
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Feb 12, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Canon pixma MP600 error code 5010
My Printer is coming up wiht a printer error B200, and i dont know what to do about it.
Jan 15, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Mar 03, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
3,050 people viewed this question
old marine
old marine
