Question about Garden
Where to find a repair manual
Need repair manual for Poulan Featherlite FL1500 Gas Leaf Blower/Weedeater.
Where can I get one?
  • Anonymous Jan 17, 2009
    my homelite leaf blower just wont start i do not know what to do i need some help
  • Jim Giesen May 11, 2010
    Whats the problem?
chad7houston
  • 62 Answers
SOURCE: Featherlite Weedeater FL1500
40:1
Posted on Oct 08, 2008
#1 Taper
  • 1040 Answers
SOURCE: need gasline size
The best way to get the correct size lines is to take a piece of the old lines to your local outdoor power & equipment store, or sometimes your local auto parts store will carry them, and let them match them up. You may have two different size lines, so make sure to get pieces of both.
Jim
Posted on May 29, 2009
SOURCE: I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Posted on Nov 09, 2009
#1 Taper
  • 1040 Answers
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Posted on Jan 05, 2010
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I can't find my owner's manual for my FL1500 blower. Where can I get a free one?
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater FL 1500 Featherlite Gas Blower Manual.
Apr 15, 2010 | Poulan Featherlite Gas Blower, with Low...
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
Looking for featherlite fl150 gas lines, where can I buy them? price?
You can get a fuel line kit from PartsStore.com. It lists for $7.95 so even with shipping charges it would be inexpensive. Here is a link that will take you directly to the ordering page: http://www.partstore.com/Model/Electrolux/Poulan/FL1500.aspx
Hope this helps!
Oct 10, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
1,525 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
