Question about Dryers
Dryer Making Lound Wobbling Noise
LG dryer 3777W has just started to make a very loud clunking sound when running. Thought it was out of level or balance, but neither seem to be the problem. Doesn't matter how large or small the load is--it sounds like it's wobbling inside.The dryer is just under 2 years old. Purchased at HD
  • ecofriendly Mar 23, 2009
    I have the same problem. I opened the top and I see that the drum is cracked in the back along the seam.
I'll bet the drum is cracked.
Posted on Mar 23, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
My dryer is making lound noise like something is stuck stuck im it
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gfg
May 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
I have a problem with my DLE 3777W electric dryer. It is level but makes a terrible noise when running, and shakes very hard. Perhaps the drum is out of wack? Please help.
The rollers that the drum roll on when it's running have bearings in them. You have a bad bearing in the roller. You can have it fixed pretty easy, or do it yourself if you know how to work on things.
Nov 06, 2009 | LG DLE5977 Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
331 people viewed this question
Top Dryers Experts
