Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
65swx20b no picture no sound
Moved tv from one room to another and now power light comes on but that is all
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Likely a bad solder connection exists and was advanced when set go moved---you might with set not plugged in want to remove cover and with flashlight have a real good look to see if any plugs loose or off.
Posted on Dec 03, 2012
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Sound , no picture
i would check connections on your convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 16, 2008
ctf1800
  • 4402 Answers
SOURCE: No Sound, No Picture
loose connection inside i would check the convergence amp area.
Convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
freetek
  • 5568 Answers
SOURCE: I have a hitachi 65SWX20B projection TV. When I
If the board with the blinking LED has larger than average parts on it, it is likely the main power supply and the clicking may be from a relay that is connecting and then, disconnecting the AC. With no video or audio, the main power supply has likely failed. Contact Hitachi service to ask how much the repair or replacement cost of the supply is. Make sure you have all involved model numbers handy; the one from your set with the mfr. date if present and if you can find an assembly number on the power supply itself. it may save you time and errors. These boards are often simply plugged into other assemblies with dissimilar plugs but if you decide to DIY, take some snapshots of the cabling to be on the safe side.
Posted on Mar 11, 2011
Samsung tv will not come on power light is on but will not show picture standby light flashes nothing else happens did this after moving from room to room
Capacitors are blown on the power board. if you keep unpluggging and trying sometimes it will come on other times not, but these capacitors will need replacing
Feb 11, 2015 | Samsung Televison & Video
I have a hitachi 65SWX20B projection TV. When I power it on, I get no picture, no sound, and on one of the circuit boards, an LED (D967) blinks dimly (1/2 second on, 1/2 second off). A soft click is...
Mar 11, 2011 | Hitachi 65SWX20B 65" Rear Projection...
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I HAVE A hitachi 65swx20b projection tv i purchased brand new the unit has been in climate controlled storage for 4 years when i moved the unit to my new home and first plugged it in the picture was very...
Yes go to SHOPJIMMY.COM You will find everything you need
including vids check it out. Make Shure you have all model # ser.#s at the ready. Good Luck
Apr 07, 2017 | Televison & Video
No Power
I'm having the same problem. Moved from one room to another and no nothing happening except the fan.
Jun 26, 2008 | Philips DSR704
Sound , no picture
Jan 10, 2008 | Hitachi 50UX57B 50" Rear Projection...
No Picture, No Sound...Please Help
The most common problem this set has is the Horizontal Output shorting, usually caused by the High Voltage transformer drawing to much current. Whether it's the high voltage circuit or the power supply, having a tech look at this set would not be cost effective. Start looking at the newer technology. Hope this helped.
May 12, 2007 | Samsung TXN2771HF 27" TV
Picture won't turn on, but sound does...
yes i beleive you some stuffs do have a feeling. anyway, the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Jan 10, 2007 | Sony KV-32FV15 32" TV
No picture or sound
take you tv to tech you have damaged your microchip and component in the power supply
Dec 20, 2006 | Samsung TXN3245FP 32" TV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
