Bad motor on electric fireplace
I believe the bearings are shot on the flame roller. the motor part # is 50tyz a 1,a/c 120v,50/60hz, 20/24 rev/min, 4w, z-p e174872
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 3 Answers
SOURCE: Charmglow electric fireplace flame does not
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Posted on Dec 28, 2009
  • 90 Answers
SOURCE: Flame does not flicke in
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Posted on Nov 28, 2010
  • 4736 Answers
SOURCE: the flame effect isn't working.
You can either purchase one from DimPlex or online from Granger Electric.
Posted on Feb 02, 2011
Flames wont move
There should be a small electric motor that turns the wheel that looks like flames. That little motor may not be working making it look like the flames don't work. May have to replace the motor.
Dec 03, 2014 | Classic Flame Nantucket Corner or Flat...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
Electric Fireplace - flame goes down instead of up
If you assembled the unit then it is possible that you have the motor installed in reverse. An AC motor should not do this as AC does not care about reverse polarity.
Feb 12, 2010 | Dryers
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My pyromaster electric fireplace will not turn on.Is there a reset button or a fuse to check?
Yes, there is a reset button. I have the same problem but the reset button doesn't do anything. I do have power but the flame does not come on.
Jul 01, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame on my electric Pyromaster is standing still is there a bulb
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
If the flame is standing still, i assume the motor is burnt out. or the belt is off.
Nov 20, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
