Question about GE JASRM24912 Remote Control
I have a Megatron TV and cannot get to the set up menu .
I am trying to change from Off-air to cable.
4 Suggested Answers
SOURCE: KV-19TS20
The cable/air setting is done manually on the front of the tv.
There is a panel on the front that opens up and the right most switch is where you set it to air/cable
Posted on Jun 23, 2008
SOURCE: need remote code for Megatron Tv from GE remote
Try 164 it works partially with mine, changes chanels, works volume etc. but doesn't do everything.
Posted on Oct 13, 2008
  • 162 Answers
SOURCE: I have a philips srp5107wm/17
Did you try and look into your manual to see if there is a different code that you can use to reprogram your remote. Sometimes that will help.
Posted on Mar 01, 2011
Do not have set up or tuning instructions
Go into the menu on the TV and look for a selection that says auto setup or auto channel scan. Once you have an over the air antenna hooked up to it then run this feature. It will automatically pick up the over the air channels. Also check in the menu and see if there is a selection that says cable/over air. You should be able to get to the menu thru the TV remote.
Dec 17, 2012 | Televison & Video
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
My t,v. jusrt goes to 6 stations and i have cable. instead of it being on cable as usual it says air where it usually says cable. It is a apex t.v. and apex control, thank you joyce.
Which model of APEX TV do you have?
In general, if the TV has had the source changed, you will need to switch it back from Air (OTA) to CATV (cable). Newer TVs may have the choices of Air and Cable for the TV source.
To change the setting, press Menu (on the TV (if present), on the original remote (in TV mode) or on a substitute remote with the Menu function). Use the up/down arrows to select the TV submenu. Select this menu with the right arrow. Then go down through the submenu to the Source line. (It may read CA-TV/Air on an older TV.) Use the left/right arrows to toggle the setting. Then press Menu to save the setting and return to the previous menu. Then go to the CH Scan option in this menu to rescan the available channels.
Note: I've gone through the directions for an older Apex TV (AVL-2076) with an analog (NTSC) tuner. The directions will probably be similar for other TVs but the menus (and sub-menus) may have different names or be in a different order.
I hope this helps.
Aug 04, 2011 | Directed 434MHZ Remote Control
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
I change the tv # 2 and now I can't get to set the signal
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Aug 21, 2010 | DISH Network 322 DTV Receiver
Cannot get to the air/cable button it bypasses. I want to change from air to cable. I have both the manuel and remote.
Once you navigate to the Air/cable setting in the menu (menu - Set up - CH setting) press the Vol + button to access. make selection once again using the CH up or down key.
Feb 25, 2009 | Sharp 25L-M100 25" TV
Need remote code for Megatron Tv from GE remote
Oct 03, 2008 | GE JASRM24912 Remote Control
Not to switch from air setting to cable setting
Check the cable company website for an updated code list; they may have developed settings for your model.
Aug 24, 2008 | Sharp 27K-S300 27" TV
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
GE JASRM24912 Remote Control Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
