Question about RCA P46921 46" Rear Projection Television
Sound Issues My RCA P46921 will go days and be fine then all of a sudden the sound is gone. I have picture but no sound. I can unplug it from the wall and then plug it back in a few minutes later and it works. Can someone tell me how to fix this issue
  • storrance Nov 13, 2007
    my tv has no sound even after I unplug it.
  • 934 Answers
I believe that's a PTK195 chassis. Yo can verify that with the small sticker on the back panel of the unit. If so, there are a number of things to test: C11637 (1uf/16v Smd) off pin 16 of U11600 R13147 surface mount off pin 50 of micro C11611 (10uf/16v) C11604 (3.3uf/50v) C11623 (4.7uf Or 10uf) Audio output IC U11901 (RCA p/n#235446) IC is located at the front left of the board as viewed from the rear of the unit. R14139 (241320) for change or open condition Q11900 SMD near output IC, RCA p/n#215495 and lastly Q11900 the mute transistor. If ANY of this has you scratching your head take it to the shop and take these notes with you... One or more of the above is your answer and none of it is all that expensive... You could save a bit of money by taking the unit into the shop yourself too. Good Luck! Bill
Posted on Jun 10, 2007
My rca f36450 has no picture or sound but does have power what can i do to fix it
There is nothing you can do to this set now. The only thing you can do, is to make a hard reset to this set. Just unplug it from AC mains socket, and replug it after a while. If this do not help you, just contact any experienced service technician.
Mar 20, 2012 | RCA Televison & Video
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Jan 27, 2009 | RCA 32V420T 32" TV
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
P61940 Sound but no picture
If you have a VCR or a DVD player, connect the red, white and yellow cables to the TV and select video 1 input on the TV.
Let me know if you require further assistance.
Jul 04, 2008 | RCA P46921 46" Rear Projection Television
Picture on TV showed as small lines at the top of the screen. Sound was fine but picture was bad. This happened while playing a video game. Unplugged TV from the outlet for about a half hour. Plugged it...
I would definitely say you have a heating up problem, im guessing either the convergance ic are heating up or HOT or horz output or a capacitor, you could try spraying freeze (radio shack carries it) when the problems starts showing up to isolate the problem.
Dec 21, 2007 | RCA P46921 46" Rear Projection Television
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
Will not turn on
This set may have a bad IHVT (flyback ) transformer. When this goes out it shorts out the horizontal output transistor. If the horz out tran is good, then check the hi voltage splitter. (Danger! there is 30,000 volts here!) Pull wire from splitter, insulate with a 6" length piece of rubber hose, and turn on set. If sound comes back the splitter is shorted. Hope this helps, Lee http://Todays-Info-Search.com http://CrazyComputers.com
Apr 23, 2007 | RCA P46921 46" Rear Projection Television
Clicking sound coming from my projection TV RCA Model P46921 year 2000
Bad Flyback xformer = P46921YX1 Part # 239111
P46921YX4 Part # 250694.....................................T.
Apr 14, 2007 | RCA P46921 46" Rear Projection Television
RCA P46921 alignment issues
I am having the same problem. Just came across this information on another website. Hope it helps. (Both of us).... http://myweb.accessus.net/~090/how2adj.html#5.4 5.4 GE / RCA / PROSCAN Read the _ SERVICE MODE WARNING _ before proceeding. To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button. You will now have some information on the screen: "P0 V0" To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value. P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual. P4 - 7 control the horizontal size, shift, vertical size and shift. You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there. If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Jan 20, 2007 | RCA P46921 46" Rear Projection Television
RCA P46921 46" Rear Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
