Question about GE Refrigerators
HELP - I punctured the Evaporator coil - is it junk now?
I live in an small apt, and I have a GE refrigerator/freezer that is so old, its model number TA1-SGB1 does not show up anywhere on the internet. The freezer is "inside" the refrigerator as a "box" with 5 sides and a door.
I was defrosting it (2 inches of ice on all sides collect every 6 months) and i punctured an evaporator coil. I knew i did because i heard a HISSSS and a blast of air shot out for around 20 seconds...then nothing. It smelled like roach spray.
Even if it doesnt work properly, is it SAFE TO plug the unit back in, turn it on and see what happens? Has all the FREON escaped? Can the leak be dangerous to my health?
I'm worried about toxic fumes in my small apt.
  • mantosof Jan 11, 2009
    Thanks for the comments.
    Its so upsetting because i have "suffered" with this old
    horrible unit for 15 years in this apt, and now that "I BROKE IT",the
    landlord will charge me through the nose for a new one (they have a policy where they raise your rent 15 dollars a month for a new fridge - which over a few years comes to many thousands of dollars for a $300 dollar model). They wont let me buy my own either.
    And i cannot hide the fact that i broke it - you can see the hole clear as a bell right inside the freezer.
    dmparenti - how old IS this model (you wrote you found it listed someplace)
I will give u an experience
if u can see that tiny puncture then u can fix it.
how? well take a 100 grit sand paper and slowly rough the punctured hole on the side of the hole approx 1 inch around it.clean it with a clean cloth. next take some petroleum ether soak a tissue in ththat and with the ether moist towel wipe the area and the hole nicely .now buy fro the market aluminium epoxy tubes. mix a little bit of the epoxy in a i:1 rratio and apply a coating of this stuff on and around the just cleaned hole.After about 12 hours the puncture is repaired now dont touch it.
Take the fridge to a professional refrigerant filling person who has experience in filling gas. he will vacuum the system and remove any ingress of moisture and then begin filling gas. your fridge will be good as new after this job
Posted on Aug 14, 2012
  • 58 Answers
The amount of freon that the unit holds is very minimal. ( like max 5.5 oz ) It will not hurt you and your apartment will be fine. But as for your unit i looked up your model and found that the evap is no longer available .Your best bet is to get a new unit ,if you plug the unit in with the freon out of the system then you will damage the compressor.
Posted on Jan 11, 2009
  • David Parenti Jan 11, 2009
    HI mantosof ,when looking up parts the ipl program (intagraded parts look up) I use doesn't tell me a manufacture date. Sorry. you might find a date on the data sticker
  • 700 Answers
You might as well not turn it back on because you let out the refrigerant and without it the only thing that will happen is the compressor wil get hot then shutdown. I would start looking for another refrigerator too and recycle that one that you have.
  • Todd Born
    Todd Born Jan 11, 2009
    you don't have to worry aabout the fumes they only are danserous if say 100 pds are released real quickly. the unit that you hacvee only has ounces in it.
  • Todd Born
    try to buy your own then the landlord cannot raise your rent,
We have a small GE refrigerator, 769T Serial number: Tax4DNY4DH. I defrosted it, and plugged it back in more than 24 hours ago. It isn't cooling. What should I do?
have you punctured the evaporator? as this can happen trying to brake the ice off as it is very soft alli, can you hear the motor running? have you tipped it?
Apr 11, 2012 | GE Refrigerators
I need to know the correct part name or number so i can order it. Punctured the coil inside of the fridge. Its the white thin metal plate hooked inside at the top. I think it serves as the freezer section...
The coil inside the freezer is the evaporator coil. You probally need a refrigerant technician to properly install and charge your refrigerator.
Aug 23, 2010 | Refrigerators
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
If you punctured the evaporator coil, causing a loss of refrigerant, then no practical repair is possible on a compact.
If only part of the cooling coil(evaporator) is frosting over with the remaining part not active, then the system either has a small refrigerant leak or the refrigerant system has developed an internal restriction, and is not a cost effective repair.
Note: If the coil was not punctured and the unit is under 5 years old you should have warranty on it.
*If that is the case, air dry the machine with power disconnected and door left open. Restart, with control set at normal, close door and recheck in 24 hours. If coil is only partially frosted, contact Sears with model number and any paper work you have. They usually keep records on potential in warranty equipment.
Oct 30, 2009 | Kenmore 91365 Compact Refrigerator
Punctured freezer coil
Depending on the make and model. Also the area you live in. You will need to have a new evaporator and a filter dryer. Hopefully moisture didnt get into the system. You could be talking anywhere from 300 and up. So I guess you can call around to make sure of the cost in your area.
Sep 05, 2009 | Refrigerators
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
1,453 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
