Existing tally. Cannot understand. Bad formula '0.45'
When i open the existing tally software am told cant understand bad formula '0.45'
5 Suggested Answers
SOURCE: Hello this is relating to Tally 7.2
Solutions
In first case when data gets corrupted while working on tally and we are unable to open the company then data can simply rewritten. Come to Company selection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that
Posted on Aug 07, 2008
  • 169 Answers
SOURCE: Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
Posted on Sep 18, 2009
  • 169 Answers
SOURCE: bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Posted on Sep 21, 2009
jimmyverdade
  • 336 Answers
SOURCE: Existing TALLY file
Do this, check-up first the printer data cable connected on the CPU. USB ports type or parallel ports for loose, damage pin or wired open. and then Reboot your PC. then try to print again.
Let me know if not yet working.
Regards
Posted on Aug 15, 2011
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
Deleted Tally Erp9 data Recovered from Hard Drive But after merge with Existing data File its not open.
http://www2.le.ac.uk/offices/itservices/ithelp/my-computer/programs/office/outlook/get-organised/open-an-existing-personal-folders-file
Dec 01, 2014 | Computers & Internet
Why is Tally saying cannot understand Bad formula '0.45'
I would try Tally Support: Support Tally Solutions
Although, they Tally suggests contacting them via their integrated support feature within the software.
Jun 20, 2014 | Computers & Internet
Existing Tally Internal Error Software exceptions c0000005 Memory access voilation
Existing Tally
Internal Error
Sep 08, 2010 | Computers & Internet
Due to power my tally system got restarted after that when open my tally it is showing one error like existing tally file damaged , manager.500 size 9846016 ..........chars 128
Bro change your powersupply into 500 wattages or higher much adviceable to use. because your powersupply cannot supply properly your entire system hardwares if it is wattages is low.
Jun 23, 2010 | Computers & Internet
Exiting Tally File: 'C:TallyDataTr01302.500 Size: 38784 Position: 38784 Chars: 128 (done 0). plz solve my problem to sawariiya@yahoo.com plz help me...........
dear sir
i have tally 9 v so my company data is not rewrite done
on rewrite position show the massage of
EXISTING TALLY
INTERNAL ERROR CONTACT TALLY SOLUTION
SOFTWARE EXCEPTION C0000005
(MEMORY ACCESS VIOLATION)
KINDLY PLZ GIVE ME THE SOLUTION FOR THIS PROBLEM
THANKING YOU
JAYESH KHARCHE
jayeshkharche2007@rediffmail.com
Nov 20, 2008 | Tally T2250 Matrix Printer
Error in tally 7.2
GO TO GATEWAY OF TALLY THAN PRESS ALT+3 = CHOOSE ALTER = THAN COMPANY NAME = CHANGE THE YEAR 2088 TO 2008
Jun 20, 2008 | Microsoft Office Professional 2007 Full...
367 people viewed this question
jasbo
jasbo
