Question about Pioneer Televison & Video
Pioneer pdp5080hd red blinking light 2 times
I have a Pioneer PDP5080HD Plasma TV 5 years old. I was watching it and "POP" The tv went off and the power red light was blinking 7 times. I doen loaded the service manual and saw that it could be the Y drive board part# AWW1260. Service shop wants $450 for this part I found a new board for about $100. It was not difficult to take the TV apart and replace the Y board. The TV now blinks red 2 times. THe blinking code looks like it could be power supply, Y Board or X board. The power supply makes more sense on what could be wrong. I think I am going to have a technician come over for $150 a hour and try to resolve the problem. I am debating on ordering the AXY1157 power board and attempting to resolve this issue. I dont have the proper volt meter and wave scope the service manual states to obtain mesurements.
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 98 Answers
SOURCE: TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Posted on Jan 24, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
SOURCE: 2 year old Pioneer PDP-5070PU plasma TV with red
While not aware of particular problems with this TV (others may know it better) based on the description and my practice with plasmas I'd be inclined to believe that one of the two sustain boards is near end of life.
Could also be problems with the power board, usually caused by dried out capacitors, but could not find reports of that through Google, so my first idea holds.
If you have a screwdriver, muscules to move it around and patience to unscrew all the bolts that hold the back panel you can actually test my theory by disconnecting each sustain in turn and seeing if the TV powers with no problems.
The sustains are the two large boards - one of each side of the display - left and right. Each sustain has a pretty fat power cable connecting it to either the power board or the other sustain (through which it may be getting power).
If I have to guess I'd bet on the Y sustain, which is the larger of the two, usually staying on the left side.
But that's just a guess - could be the other as well.
And, of course, could be just about anything else.
This is just best guess based on experience.
Bobby
http://www.coppelltvrepair.com
Posted on Jan 23, 2010
diodeic
  • 1622 Answers
SOURCE: I have a Panasonic TH-50PX75U Plasma 50" tv. The
All you need to do is to open the back cover of the television to check for burnt transistor , this is always the problem , for you to fix this it require a basic knowledge on electronics,
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help out in solving the problem
Posted on Dec 19, 2010
Pioneer plasma tv model pdp436pg
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 10, 2014 | Pioneer PDP-436RXE 42 in. HDTV-Ready...
I have a pioneer pdp5080hd....When I turn it on I have a blue and red light on.....no picture...the lights donot blink...
ok when u took the cover off there is a switch u should push the switch and put a tape on it never turn on when the cover is off unless the switch is pushed now change the main digital board and push the switch the tv is gonna come on
Jan 27, 2011 | Pioneer PDP-5080HD 50 in. Plasma HDTV
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Tv does not respond to turn on
the blinking light is to signify which break the error or short is happening it its used by tv repair men to diagnose the problems early on it will however require a technician
hope this helped
Robb
Apr 25, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
I heard a pop from my tv and then the tv didn't work
Anything is repairable as long as the screen isn't damaged.
The sound you heard is most likely was a capacitor that just went dead.
Solder in a new capacitor should fix the problem. It would most likely be on the power supply board somewhere.
You'll need the Service Manual for parts list, diagrams, and schematics. Here's one place for that:
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=pdp-503cmx+service+manual&forward=plist
Any other questions just ask.
May 10, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer PDP506-HDG plasma tv
The 3 blinks ( i assume they're blinking in red) means a scan assy problem. Check the scan A & B boards and the Y drive board. Something is shorted and loading down the Vscan voltage of the power supply.
C-Dog
Dec 19, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
