Question about Garden
Runs on full choke 1/2 choke shuts down
Doesn't keep running
  • 2,239 Answers
Start with the simple inexpesive things first, replace the fuel filter in the tank, check the fuel hoses up to the carb for cracks or leakage, replace if required.
Posted on Dec 08, 2012
  • 59 Answers
SOURCE: Blower only runs with full
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Posted on Mar 14, 2011
  • 97 Answers
SOURCE: leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Posted on Mar 19, 2009
  • 6 Answers
SOURCE: Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Posted on Mar 20, 2009
rycgl
  • 1545 Answers
SOURCE: Ryobi CS30 Trimmer starts and
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
Posted on May 22, 2011
rycgl
  • 1545 Answers
SOURCE: I bought an Echo PB-250
The carburetor is exhibiting symptoms of flooding. Many different things can cause it, from a bad vent in the gas cap on the machine to bad seats on the L and H mixture screws of the carburetor. I suggest you remove the carburetor and clean it, (use NO harsh chemicals) and have it rebuilt. If it sat over the winter with old fuel in it, the diaphragms inside it are probably ruined. There are NEW ones in a rebuild kit.
Posted on Jul 12, 2011
Choke doesn,t work plungger moves up & down but it runs just fine with the choke on
you have a gummed up carb. take it off and run carb or brake cleaner through all the passage ways and remove all the jets and shoot the cleaner through them
Apr 10, 2013 | Motorcycles
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Runs only on half choke
Before you take it a part adjust the fuel air mixture most of these small engines are air 1 1/4 and fuel 1 turn get it to ideal just before the foot spins ( let the engine warm up good and have fresh fuel before doing these adjustments) afer a good ideal adjust the mixture for a full no bogging speed . If this does not work then start to work on the carb.
Jul 20, 2012 | Garden
B&S Engine Model204412 code 060613YD runs well even under load with choke full will stop if youput choke back to normal
Hi check float level if it's to high ::::::: it's possible the seal inside the needle & seat is faulty u will have to buy a needle & seat package. . cheers
Feb 12, 2018 | Briggs Stratton IC Horizontal OHV Engine ...
My 1981 Honda "CB750K" runs rough at low rpm and
1 and 2 run off different coils so its not electrical
do a compression test after checking all valve clearances
clean the carbs
check for any cracked hoses to the fuel tap,
and check for fuel tap operation, and its not running on prime, no fuel should flow in the run or reserve position until the engine is running.
Oct 27, 2011 | Motorcycles
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 05' Yamaha 650 V Star and it will only run if the choke is fully out, hot or cold engine. If the choke is pushed in, it immediately dies.
Has the bike been parked for two weeks or more? If so, the fuel has most likely gummed up and plugged fuel passages and jets. Might try adding 1/2 to full can of SeaFoam to existing fuel in the tank, crank the bike and run (with choke if you have to) at a high idle for several minutes. Shut it down and let set for an hour or so allowing the SeaFoam to work. Start bike again and run at high idle again, trying to run it without the choke. If this doesn't work, then the carb probablyneeds a tear down and a manuel cleaning and reset.
Apr 13, 2011 | 2004 Yamaha V Star Classic
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
