Question about Canon imageRUNNER iR C2880 Color Copier
Ir c2880 will not boot
Immediately after the service contract ran out, our iR c2880 copier/printer requested a restart, then failed to reboot, ie. the progress bar on the screen stops at ~50%. No error codes. RAM, boot ROM have been reseated. Our best guess is that the HDD has died. Transferring the HDD to a spare PC, the drive makes the click-of-death noise. Any thoughts on replacing the HDD + system software without paying Canon $2K?
Ir 2880 says insert black cartridge
Hi there, please whenever i pressed *28* to enter service mode on my canon ir2200i, i got this screen that shows download mode
Please your assistance will be highly appreciated
Thank you all
Jan 24, 2014 | Canon imageRUNNER iR C2880 Color Copier
Error code on display E0000045-0000
Canon imageRUNNER iR C2880 Color Copierchange the drum unit, or try to dismantle it and clean but these is not recommended.
Aug 23, 2011 | Canon imageRUNNER iR C2880 Color Copier
I have canon ir 3300copiyer machine i want service manual
send me mail on emma.servis@gmail.com and I will send you service manual.
Do you have some problems or You just want for "in case scenario"?
Regards!
Aug 06, 2010 | Canon imageRUNNER iR C2880 Color Copier
Reset/change Remote UI Name and Password on iR C2880
I think that username is: admin, and pass: 0000 or 12345. If that doesnt helps you wrote on emma.servis@gmail.com for service manual.
Jul 29, 2010 | Canon imageRUNNER iR C2880 Color Copier
We have a Canon C2880 and it has started to print blank pages for no apparent reason. Toner cartridges are OK.
You need to check the laser shutter and transfer bias. Best solution would be to call service.
Unable to scan from Canon IR C2880 to computer desktop. Looking for manual for specs.
got to canon.usa.com and download the user manual. or go to google.com and type in User manula for the canon ir c2880 copier
Jul 12, 2010 | Canon imageRUNNER iR C2880 Color Copier
How do I get to the drum cartridges on our Canon IR C2880?
open front door remove clip on cover to righthand top push lever in and right hand lower door will pop open remove 2 screw 1 top left 1 top right release black handle and the whole assyembly draws out press button on top and lift up there is a little black support arm to stop it falling down unlock the drum you want to change and remove or just call the engineer if you have a service contract?
Nov 16, 2009 | Canon imageRUNNER iR C2880 Color Copier
C2880 tray 1 lifter
pull out tray see if there is paper stuck in side were the tray slides
Oct 23, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imageRUNNER iR C2880 Color Copier Logo
32 people viewed this question
old marine
old marine
