Question about Dell Inspiron 1501 Notebook
Monitor Flickering to green on Dell Inspiron 1501
I have a 1501 that the monitor flickers to green, i suspected the cable between the board and the monitor but it doesn't seem to cut out when i move it around. Computer is responsive still, just the monitor seems to be affected. Running Windows Vista Home
  • 1 more comment
  • thomvoth Jan 11, 2009
    Sorry, I used the wrong terms, its the laptop screen itself. Thanks though.
    K I just tried it on my TV and its doing the same thing, so the video card must be the issue.
    Did that already, that was my first though too. It is doing it on its own screen and also through the VGA port. I will see if I can update the video drivers.
    Novelist:
  • 180 Answers
Since the cable isn't the culprit as you determined by moving the cable around. This leads the problem to be either the video card (built in or not) in your PC or the monitor itself. The best way to test this is to switch your monitor with someone else and see which one duplicates the problem. If the monitor is the problem, the good news is that you can find them on sale for cheap online. I found a 19" for $99.99 and am quite happy with it.
The only other thing I'd suggest is updating the drivers for the monitor through Device Manager (right click My Computer>Properties>Hardware>Device Manager). Expand Monitors and Display Adapters. Right click what is displayed and choose Update Driver. This most likely won't be the problem fixer but is worth checking out.
Last question...how old is the monitor ?
Posted on Jan 11, 2009
  • Bill Speer
    Bill Speer Jan 11, 2009
    You can go to support.dell.com and look up the manual for your laptop. It will show you how to take off the monitor. There is a good chance one of the cables needs reseated. It's a relatively painless procedure if you're even a little handy with tools.
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
I'm running dual Samsung 305T monitors and one of them has been flickering from time to time. It just starts to flash and flicker. Now, it's all green and fuzzy. Still can see everything, but it's got a...
The flickering problem you have is caused by the monitor's t-con board, The Altera chip on the T-con board is having a bad connection because of dead soldering points or cracked soldering joints, the solution for this problem is to have the T-con board Altera chip reballed, its a very advanced repair , only one place will fix it for you and I will add a link for it, you won't easily find a replacement T-con board for this monitor and Samsung is no longer supporting your monitor so that place is your only hope. 7f514c27-5c9c-4e70-b50a-29505054d67b.jpg b5ec5af6-395e-4533-b5ea-9ca10c5ae592.jpg SAMSUNG MONITOR 305T REBALLING REPAIR 728a6cd3-2218-4f75-8f0c-7348e47d15f4.jpg
Aug 02, 2013 | Samsung SyncMaster 305T 30 in. LCD...
Dell Inspiron 4100 flickering off and on Makes it extremily hard to work with . How can I tell whether it is the display or something else?
What happens when you hook it up to a external monitor? If it works fine with a external monitor, then your laptop monitor is going bad. If it does it with an external monitor, then its more than likely an issue with your laptops video adapter.
Oct 21, 2012 | Dell Inspiron 4100 Notebook
Laptop monitor flickering
You could have a faulty ribbon video cable or a loose video connection to the motherboard. Reseat the video cable connection to the motherboard.
To get to this connector you most likely need to remove the keyboard to get access to this connector.
Mar 30, 2012 | Dell Inspiron N5030 Notebook PC
Flickering
If the screen of your monitor is flickering, this is indicating that your picture board is about to go bad or already bad, but i would suggest you replace the cable that connect to the monitor before concluding on this, if after replacing the cable, problem still persist, you will need to replace the picture board on the monitor to solve the problem.
Take care.
Jun 29, 2010 | Compaq TFT450 14" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
Display blinks rapidly
Yea if possible try to check if the monitor cable that is connecting the monitor to the motherboard on he laptop is lose. Then give your laptop's video card drivers an update. If that doesn't help then it could be something physical wrong with the video card. Or something physical wrong with the monitor controller board. You'll just have to isolate the problem to find the reason for the issue.
Aug 18, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
528 people viewed this question
Alun Cox
