Question about Vizio P2 42 in. HD-Ready Plasma Television
My vizio plasma has sound black screen
My Vizio 42 inch plasma has sound, but a black screen. I put a new power cord on it and it still has no picture what do i do next
  • 1,238 Answers
Your Tv possibly have faulty y sustain board, just replace that board to fix the problem
Posted on Dec 03, 2012
SOURCE: help - 15 mth old 42" edtv "plasma" black screen" have power and sound
I had the same problem....wasnt the main board but the two smaller boards...vizio changed them and no problem since .....
Posted on Feb 19, 2008
SOURCE: VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
Posted on Aug 11, 2008
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Posted on Nov 02, 2009
anewzack78
  • 16 Answers
SOURCE: Ihave sound, but no picture.
There is a problem with the video logic board. You could take it to a repair shop or diagnose it yourself with a multi-meter looking for blown up capacitors/burnt parts.
Posted on Jul 21, 2010
Found a 42 inch Vizio flat screen with no cord...bought cord for power...when I hit power button the word Vizio appears in center of screen then shuts off 2 seconds later...can this be fixed?
it had no cord because it was no good
it probably could be fixed but the cost would exceed a new one which is probably what the original owners did
May 23, 2016 | Vizio Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
i have a 42" cracked vizio screen, where can i find a replacement screen?
Jan 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio plasma hd 42
Sounds like you hit the PIP (picture in picture) button on the remote. Hit it a few more times and it should go away.
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio plasma
Ok call up vizio 877 698 4946
have model number and serial number ready...
If its uder warrenty its fixed even if its3-4 months out they SHOULD cover it!
IF not you need 2 new boards and another board.. cost on the y and z board I believe is 220 for y 220 for z 210 for power baord and 210 for them to come fix it 9--$ total
THATS FROM THEM my vizio is may 2006 vizio and thats their solution. They told me it might only be one or the three boards and the part number is 8004328542! They said I could buy it and see if it works where to get the part.. online I guess bc there is no way in H--- that I would pay 210 for the part from them.
A used vizio on ebay for a 42 inch is 450 plus shipping so why waste my time!
If you want to talk to them here is their number800 762 0796
May 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No picture but has sound
With all the listed sets,itis most likely the y-drive(sus) board.The only problem is that this board usually fails when the horz.buffer ic's fail,which is usually part of the plasma display.This was a semi-common problem with this set.The best bet is to find a new set,since the parts alone will exceed the cost of a new one.Pioneer or nec seem to be the most reliable that i have seen.
Jan 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
238 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
