Question about Rancilio SILVIAespresso&cappuccino machine
Tripping high temp cut out
Model;Miss Rancilio, Kathy
this machine buildin up too much pressure and tripping hi temp cut out.is there any adjust temperatur on this unit?
Thank you,
Clinton.
  • Anonymous Mar 12, 2014
    I am getting a constant voltage to the element and it is not cutting out when it gets up to temperature. I have changed the Control pcb(the one in the black case under the driptray), pressure sensor and overheat stat but still not working. Any help would be a great help.
    President:
  • 1,618 Answers
The temp on the machine is set by one of the 3 thermostats on the boiler, check resistance and replace the faulty thermostat.
Posted on Mar 25, 2009
Ecm Giotto
Have you checked the Thermostat on the unit in the tank if it is stuck it will cause the tank to over heat and pop off the steam valve?? there should be some resettable overheat protectors as well. Has the preassure relief valve been replaced as well??
Feb 14, 2008 | ECM Giotto Espresso Machine
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Jan 12, 2015 | Rancilio Silvia Espresso Machine
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
Rancilio silvia trips circuit breaker
There is an electrical short within the machine, ...don't doubt it - the results of your experiments prove that it has an electrical fault and that your tripping circuits are doing exactly what they should to keep you and your property safe.
The machine needs servicing by a registered Rancilio electrician, don't go inside yourself, its highly likely that the part causing the tripping is dangerous and will need to be replaced.
Apr 19, 2013 | Rancilio Silvia Espresso Machine
How do I change the water pressure (bar) on my Rancilio Classe 6 E 2GR?
You will have to adjust the pump. there is an adjustment nut on the side of the pumphead, if you screw it in that gives you more pressure, and if you loosen less.
Sep 19, 2011 | Rancilio Classe 6 E 2 gr Espresso Machine
Rancilio S24 Pressure adjustment
Rectangular box on the back of the machine, it is easy to reach it from the top, there will a + and - sign on the slotted screw to show which direction to adjust.
Jan 07, 2010 | Rancilio S24 Espresso Machine
My Rancilio Epoca E1 espresso machine has no steam
It is possible that the reset connected to the boiler tripped.
Sep 29, 2009 | Coffee Makers & Espresso Machines
Rancilio Epoca DE 2 group espresso machine
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
Jun 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio SILVIAespresso&cappuccino machine Logo
217 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
