Question about Goodman Heating & Cooling
I have an old emailair air conditioner and cannot find the remote controller. I have tried to turn it off manually but it is still blowing out air. How do I turn it off manually?
bobotfel
  • 236 Answers
SOURCE: Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Posted on Jan 02, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
This is the standard meaning of symbols in the remote control.
Posted on Mar 02, 2008
22yooper
  • 828 Answers
SOURCE: AIR CONDITIONER COMES ON BUT DOES NOT BLOW COOL AIR
It is possible that your unit needs refrigerant but Before I would have someone recharge it they would have to locate the point of leak and repair it. I would check to make sure it is not some other problem first, like is the compressor operating.
Posted on Jun 16, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
How do I find a fan or fan motor for an Emailair air conditioner 110RC Room
you have to find an appliance parts house you can chesk online to you will need serial no. model number. rotation of the motor amps and hp. the best i to take the motor with you
Jul 20, 2014 | Heating & Cooling
Need new remote
Most "generic" remotes can be programmed to work on most brands. Have a look at the back of the packet the remote comes in, it will show which makes / models the remote can be programmed to. In a lot of cases, the generic remote is a lot cheaper than a genuine one however some functions may not be accessible. IE/ Sleep or timer function. Dick Smith electronics or a general electronics store may have them or an air conditioner parts outlet will have them such as Heatcraft, Airfridge, Airspares etc (In Australia)
Mar 29, 2014 | Heating & Cooling
I cant get cooling from my air con,model-emailair WS066H,but I do not have a remote control for it,can i control it manually.
Only in some models, there is an option to operate manual. Check near indoor display. If there is button press it. But you can't change temp setting and mode as you like.So, It's advisable get new remote.
Dec 29, 2010 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
64 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
