Question about Epson Workforce 520 Printer
Epson workforce 520 does not recognize ink cartridges
I put in new cartridges but display saying that printer does not recognize cartridges even though they are Epson
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
Posted on Mar 12, 2008
  • 526 Answers
SOURCE: "Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Posted on Jun 27, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Posted on Aug 21, 2009
arjoy
  • 87 Answers
SOURCE: My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
Posted on Jan 28, 2010
Scanner Error - After installing 1st time Remanufacatured Ink Cartridges
Remanufactured cartridges have too many problems. I have be using refillable with auto-reset chips and never have a problem. Google- refillable cartridges and be sure to use the proper ink, dye base or pigment. It makes a difference.
Apr 09, 2014 | Epson Workforce 520 Printer
Epsom 520 printer problem
Bad printer nozzles, faulty cartridges and or ink.
Mar 19, 2014 | Epson Workforce 520 Printer
I put in refurbished printer cartridge and printer stopped printing properly
yep, that will do that. Non genuine cartridges are notoriously un reliable and this issue is extremely common. We only recommend the use of genuine ink cartridges for all printers. Try removing the dud cartridges and put in the genuine ones. if that fails, you may have distroyed your printhead, in which case, go and replace you printer, it is cheaper than getting it fixed.
Feb 15, 2014 | Epson Workforce 520 Printer
Will not print after changing ink cartridges
Defective cart or not genuine cart. Also be sure cart is installed properly, take it out and put back and listen for the click.
Jan 27, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Epson WorkForce 520 Series How to check Ink Levels ?
Click on the Printer icon on the task bar and select buy ink.
Alternatively, In the Start menu select Epson>Epson Workforce 520 >Buy Ink.
Oct 25, 2013 | Epson Office Equipment & Supplies
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
I put new ink in it, now it won't print, it is
If you only filled the cartridges with ink they will not work.
The chip on the cartridges needs resetting.
To do that you would have to buy an Epson cartridge chip resetter..
Feb 20, 2010 | Epson Workforce 30 Laser Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Epson Workforce 520 Printer Logo
262 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
