Insignia NS-42PDP plasma tv turn off on its own and can't be turned without disconnecting power and the restarting
    Sergeant:
  • 258 Answers
Power supply capacitor dried out bulged.
These are terrible televisions and all plasmas generate a lot of heat and dry out the cheap capacitors they use on the Psu board.
Posted on Dec 02, 2015
  • 1,238 Answers
You possibly have bulged capacitor on power supply, just replace it to fix the problem
Posted on Dec 03, 2012
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
  • 2318 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
  • 146 Answers
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Posted on Jan 30, 2009
  • 2318 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Posted on Jun 29, 2009
  • 5 Answers
SOURCE: INSIGNIA NS-37LCD MANUFECTURED OCT 2006 DEAD NO POWER
found caps in power supply bulging so i replaced all electrolytes in power supply but TV still doesn't work when i hit the power button the power supply just ticks.
Posted on Jan 29, 2010
Why does my TV turn on then off when i turn it on either by the remote control or the power button on the TV?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 29, 2016 | Insignia 42" Flat-Panel Plasma HDTV
Tip
Insignia NS-PDP50 Manual Download
Download Insignia NS-PDP50 Plasma HDTV Manual
Have you misplaced your Insignia NS-PDP50 Plasma HDTV Manual ?
Would you like a digital, searchable, pdf version of the Insignia NS-PDP50 Plasma HDTV Guide?
Follow this link (& click FREE) to download a pdf version of the Insignia NS-PDP50 Plasma HDTV documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Insignia 50 in. Flat-Panel Plasma HDTV
My insignia NS-LTDVD19-09 turns off 3 seconds after I turn it on.
that"s very difficult thing without any test by multimeter & just look at it yes you right no any physically damage at least . maybe power supply working fine. maybe done gone in already.you need a technician for troubleshoot it.
Sep 07, 2012 | Insignia NS-LTDVD19-09 LCD TV
I have an Insignia tv model NS-27RTV that i got at a yardsale without a remote & i'm trying to hook up my xbox 360.
Here i have added a link to the remote of Insignia NS27RTV. Without the remote its not possible to access the AV input.
Remote
Ajin
Jul 22, 2012 | Insignia NS-27RTV 27" TV
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
Looking for tv stand for 32" Insignia flat screen
  1. 32 TV Stand- Ship Free1700+ TV Stands Arranged by Size, Price, Color & More. Lowest Costs!
    Exclusive Deals - Gift Certificates - Best Sellers -Entertainment Centers on Sale www.tvstands.com
  2. TV Stand For 32 InchGreat Selection of Brand TV Stands. Free Shipping on Your Order Today! Google Checkout thesimpletvstandstore.com
Jan 28, 2011 | Insignia NS-RTV32 32" TV
Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
Aug 06, 2009 | Insignia NSLTDVD26 LCD TV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
