Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My Philips Rear Projection tv 64" has a bowing in it at the top and bottom of the screen. I used the converge and the multipoint but it did not fix the problem. The picture has a double look to it at the bottom and top as well like a shadow.
    Scholar:
  • 87 Answers
You have bad convergence amps and possibly a couple of bad resistors
Posted on Jan 12, 2009
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Convergence problem with Philips 60PP9352
Screen looks 3D
Solution:
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
Screen looks 3D
Solution:
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Picture Quality
Sounds like your convergence amps are probably bad. Check out http://i114.photobucket.com/albums/n248/OFilippov/Dont%20look/Pioneer/BadPicture03.jpg and see if you have similar bowing between red and green when you try multipoint convergence. If so, you'll need new convergence amps, part STK392-120. Most people who are handy with a soldering iron can replace these parts in a couple hours.
Jan 15, 2008 | Philips 60PP9202 60" Rear Projection...
Bowed screen on my philips HDTV model #60pp92020
Sounds like your convergence amps went out. See other postings here for how to fix.
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
