Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Need valves adjustment ona22hp v-twin intex thats in a troy bilt riding mower
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Briggs & Str... Expert
  • 133 Answers
Use a business card its the easyes way to gap them
Posted on Mar 12, 2013
4 Suggested Answers
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 6 Answers
SOURCE: LAWN MOWER WILL NOT START
The compression relief valve is not working. Pushing the engine past top dead center and turning the key works after a fashion. Keep the battery fully charged. This is a design/engineering fault in B&S engines which they cannot fix. It is in all of their engines. Most do not malfunction but those that do, do it all the time. I have had the compression relief valve replaced and the valve settings set to allow the valve to function (it uses the exhaust valve by holding it partially open while starting) but it still does not work properly.
Skip the below portion if you don't want to hear a negative view of B&S engines.
The engine problem resolved itself today (12-10-10) when it threw its rod into the cylinder wall. B&S engines power a huge number of the riding mowers in the US. It is difficult to escape them when buying a mower. Use it on more than a postage stamp yard and B&S will claim you abused it.
Posted on Dec 11, 2010
  • 250 Answers
SOURCE: does a briggs 18 hp
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Posted on Mar 17, 2011
Troy-bilt bronco riding mower will not travel.
Possibly need to be adjusted the pedal tensioner.
Good luck
Mai
Feb 05, 2017 | Troy-Bilt Garden
Adjust clutch pto
normally they work by spring lock system, follow the bar under the hood or engine and check if any broken or missing spring or parts often bended by running over things
Aug 08, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
140 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
