Question about Hayward SAND FILTER, PRO SERIES
The pool place is telling me that they don't make the spider gasket for my filter valve and that I have to replace the whole thing. If I can take the gasket out of the valve, why can't I get
If it's true, are there any home remedies or tricks of the trade that someone has used to get around the problem of buying a new valve assembly.
  • 8,404 Answers
Send inquiry to Hayward of you are unsure of your pool supply place.
Hayward will know the answer to your specific valve.
Posted on Dec 10, 2012
mattofilms
  • 110 Answers
SOURCE: pool filter is not filtering the dirt out of pool.
will replacing the sand make any difference?
Only if you have very dirty sand. -But seeing as you have backwashed it - I would say it will help but not fix prob.
Have you got all pipes in right holes?
Did you put head stock on right way?
Posted on Jul 07, 2009
  • 351 Answers
SOURCE: after replacing gasket on filter vacumed pool
I would suspect that there is a fault in the filter, a bnreak in the filter elements, a bad alignment, a colapsed support. something that is letting the dirt get back in to the pool
Posted on May 04, 2010
tecnovative
  • 360 Answers
SOURCE: while vacuuming my pool, valve
Hi, my name is John I will do my best to assist you.
Normally the valve head on these sand filters has a selection for "Pump To Waste" this is the setting that should be used when vacuuming. The pump water will flow out the backwash hose/line so that the contaminated water does not flow through the filter and back into the pool.
A lot of water is pumped out using this process, so it's a good idea to have a water hose refilling the pool while you work. Unless you can work quickly you may not be able to completely clean the entire pool at one time. Pay attention to the water level, and when it drops to the low level mark on the skimmer stop and wat for it to refill.
The "Filter" selection is typically intended for normal pump circulation only.
If you have more specific questions please post comments to this thread and I will endeavor to monitor new activity and respond as soon as possible. I recommend that you "bookmark", or "add to favorites" this page for your convenience.
Posted on Feb 15, 2011
aquaman987
  • 927 Answers
SOURCE: I have a hayward SP714
Sand filters have a screen at the bottom. This screen keeps the sand from getting out because it has slits or holes that are smaller than the size of the sand grain. The slits are large enough for the water to pass. If the material breaks there are areas that are large enough to allow the sand to pass and this won't stop until you replace the strainer elements.
In order to do this, you must remove the sand, remove and inspect the strainer and replace the sand.
Bring your model to a local pool supplier, confirm what I am saying, make sure they have the necessary parts and go from there.
Gary
Posted on Feb 26, 2011
jharwell668
  • 640 Answers
SOURCE: While vacuuming my swimming pool
Try changing the setting on your pool filters control valve to waste. This will bypass the filter and vacuum directly to waste. If this works, it could be a problem with the filter's "filter" setting and you may need to service or replace your control valve.
Posted on Mar 15, 2011
Hayward pool filter Model SP711 alignment on filter, ports, spider gasket replacement
Remove the 6 screws from around the valve assembly. Pay close attention to the current orientation of the valve assembly before removing. Lift the value assembly straight out and the spider gasket is on the bottom. This could be twisted a little which would also cause your back flush port to leak when positioned in the filter position. If twisted, just position back in alignment with the valve holes on the bottom of the valve assembly. If the gasket is worn or torn then just replace and place the valve assembly back in the valve housing and replace all 6 screws. If you still have problems with water not functioning based on the way you have the handle turned then it might be time to replace the entire valve assembly.
Jun 15, 2014 | Hayward SAND FILTER, PRO SERIES
Is there another solution to fixing the spider gasket on my heyward filter other that replacing the whole valve assembly? Are there any home remedies out there.
I would try to change the gasket first ... be sure you look at the gasket BEFORE you remove it so you can put the new one in properly. Typically, it is the gasket that goes and not the valve. Remember, you can only turn the handle in a clock wise direction - never backward. or is that counter clock wise ... :-)
Dec 06, 2012 | Hayward SAND FILTER, PRO SERIES
Water leaking from backwash even after replacing spider gasket
The Cam portion of the valve is worn. replace the "Spider Web" 4 times always replace the cam also on the 4th time. be sure to use a good HEAVY pool lube, I prefer Jacks 327.
Jun 29, 2012 | Hayward SAND FILTER, PRO SERIES
This spring we changed the sand in our filter. Sand was purchase from the same location we purchased our pool. When i vaccuum the pool the dirty water is sent out the return back into the pool and the...
I don't like sand filters very much but that still should not be happening. If you have a multiport valve on your filter, take it apart and see if the spider gasket is in good condition and if it's secure. Sometimes if a spider gasket swells it can push its way out of the grooves where it is fastened. Also, if you have ever turned the multiport selector know without fully depressing it, if could have pulled a part of the gasket out and it's now letting water return to the pool without being filtered at all.
New sand should not be causing this problem, check your multiport and see if that is the problem.
Hope this helps
Jul 30, 2011 | Hayward SAND FILTER, PRO SERIES
I have a brand new filter..im leaking lots of water from my backwash when on my filter setting
Your multiport spider gasket is bad. Just replace it by removing the top assembly. Remove the 6 phillips screws on the valve cover and the whole assembly will come off. This is easiest done when the valve is first put on the "Winter" position
Jul 21, 2011 | Hayward Pro Series 18" Above Ground Pool...
What is the spider gasket?
A spider gasket is used in a multi-port valve on a pool filter. It is the thing that is damaged if you run the valve arm in a counter clock-wise direction.
Hope this helps ...
Thanks for your question @ FixYa.com
May 04, 2011 | Pentair FILTER TANK BOTTOM, 48 SQFT
Sand is being pumped into the pool
This usually indicates a broken spider gasket in the top valve. Your local pool dealer should have a replacement. it is simple to change, just remove the screws at the top of the valve around the flange and the spider gasket shoud be visible. Take to the dealer and get it replaced.
The Pool Tech
Aug 07, 2010 | Waterway 22" Swimming Pool Sand Filter W15...
I'm getting DE back in my pool from the 4820 filter
One of two things can cause this. Either the spider gasket is bad or there is a rip or tear in one or more of the filter grids.
P.S.
(the spider gasket is inside the valve you turn to backwash filter)
Mar 25, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Need to relace spider gasket
your better off replacing the top half of the multiport valve.
Sep 25, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
110 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
