Question about Compaq Presario SR1000T (568657) PC Desktop
Front panel Ac Switch failing to start computer.
The power company I have has had several power failures in the past and after one such power failure my computer failed to boot back up immediately. Pushing the power button resulted in no responce,... however after several attempts it booted fine. I had since left the computer running and began researching the problem. When trying to start the computer the front panel switch LED lights up momentarily,... both the internal and external fan spin and then the computer goes dead again. Another power failure had occured. The hour long process of repeatedly pushing the switch usually resulted in many flickers and short bursts of power to the internal fans with an inevitably successful boot up. There has been no responce at all. No flickers, no fan movement, just a dead computer. Current suggestion is the power supply being faulty,... the LED light on the back of the AC Power Supply is always on when plugged in,... but,... if I unplug it and watch that LED light as I depress the Front panel switch,... it does not immediately go off. I believe the switch just isn't connecting anymore. Can you help me understand this problem and how I might fix it?
    Scholar:
    New Friend:
  • 42 Answers
Try these steps.
If Power supply light does not turn on (or no power supply LED)
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
NOTE: If the Power Supply fan spins when the PC is turned on but the light does not come on, it is possible the LED is defective. If this is the case, use the section Power supply light comes on or flashes .
1. Disconnect everything from the PC, including the power cord.
2. With the power cord disconnected, press the power button on the front of the computer. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
3. Replace the power cord with another power cord, like the one used by the monitor.
Test to see if the computer can turn on. If not, continue using these steps.
4. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
5. With the power cord removed, flip the red voltage selector switch to the opposite position, wait about five seconds, and then switch the red voltage selector switch back to its original location.
This ensures that the voltage switch is engaged and set correctly for your country/region.
6. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
7. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
8. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
9. Use a vacuum cleaner to remove the build-up of dust from the power supply fan vent holes. Make sure that the PC is turned off and that the power cord is plugged into a grounded outlet. Only use the end of the vacuum hose near the outside of the fan entrance.
10. If all of the above steps have been tried and the power supply light remains off, use the steps in the next section, use the next section Power supply light comes on or flashes , to reseat the cables and check the power switch connector.
Posted on Jan 12, 2009
  • Ganesan Chandraiah
    Ganesan Chandraiah Jan 12, 2009
    If Power supply light on or flashes
    CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
    1. Disconnect everything from the computer, including the power cord.
    2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
    3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
    Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
    4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
    5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
    NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
    1. Remove all attached devices except for keyboard, mouse, and monitor.
    2. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
    3. Check the power switch:
    a. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
    · If the button sticks, it should be replaced or serviced.
    · If the power button does not stick and appears to be functioning, continue using these steps.
    b. With the power cord disconnected, remove the case or side panel.
    c. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    d. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard.
    e. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    4. Find the defective part:
    a. With the power cord disconnected, remove the case or side panel.
    b. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference.
    c. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
    · If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
    · If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
    · If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
    NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement. If the power supply was damaged due to power outage or storm, this may not be covered under the "act of nature" policy in the warranty statement. Refer to the warranty statement that came with your computer for more information.
    Problem Solver:
  • 10 Answers
Or you can buy a new power supply. because if you not qualified
best to leve it alone
Posted on Nov 20, 2013
What can cause air conditioner fan to not work?
split systems
the inside fan works all the time when on so that the room air is circulated past the thermostat
the outside fan only works when the compressor is working to cool the condenser coils
with the inside fan not working it indicates a power board failure , power failure or control panel problem
if it is a window (box ) ac then it will be the power board problem
in either case it is a job for a ac technician as it could be just a start/run capacitor fault.
Jul 09, 2015 | Heating & Cooling
Need to fix G62 computer:will not start
"Worked in the past, doesn't work now", That's sort of the definition of a failure. Has the laptop been dropped? What does the laptop when you try to start? Do you see LED"s blink? Fan spins? HHD LED blink? Battery light on? Has the AC jack been damaged due to pulling on the cord? Did you try a cord/charger with the EXACT same power spec? Test the DC volts at the laptop cord plug with a multimeter. Reseat the Memory mods. May be a HDD failure? Post results
Feb 02, 2013 | HP Computers & Internet
After A.C. power failures, my Panasonic DMR-EH55 does not come "to life" again (even in "off mode"). Removing it from the power for several days then trying again (and repeating this if...
Possible that the main power supply has failed and so it is important that with your skills you must be able to check the power to the SMPS - switch mode power supply.
If power is good then the processor must be checked or there is failure on the motherboard.
Check this link;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 03, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
My pc beeped twice and nothing came
Lack of video signal is usually 1 of 3 things, Power supply (PSU), Video card or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #1A: You might get some power lights coming on and some fans spinning but the video output does not happen, usually indicates that motherboard or PSU is going out or has gone out. Occasionally it will be due to a weak (damaged) PSU.
Situation #2: If you get sounds (normal Windows startup sounds) and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat (take out and then put back in) try that. If it is onboard video then you may have to buy a video card for it.
Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Do you hear anything else during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. Do you have the 4 diagnostic (A,B,C,D) on the rear of the machine? What is the front power light on the CPU doing?
Apr 29, 2009 | Dell Dimension 2400 PC Desktop
My tv wont turn on
Not that it is pertainent but it would be interesting to know which ICs you replaced and what caused you to suspect them; was the set dead before as it is now?
Generally, no video and no sound points to a power supply failure. Sometimes they will get slow at turning on, and others may fail completely; these two failure types can indicate different failure modes.
The type of failure that causes hard-starting power supplies is often cheap to repair whereas a failure that suddenly occurs can be more costly and involving more labor to resolve.
Pasted below is my usual suggestion for suspected power supply failures: --If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Oct 31, 2008 | Philips 60PP9202 60" Rear Projection...
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Toshiba Tecra M2 Series
Was the laptop on when it turned off? It may be a PSU problem but we can determine this by removing the battery. Make sure you disconnect the AC adapter while your removing the battery. Inspect the contacts and make sure`there are no black marks or any other dirt. Leave the battery out and plug in your AC adapter. Try the power again.
There are a couple of possibilities in terms of problems that I can suspect so far. Did anything out of the ordinary happen when the computer just stopped working all of the sudden.
1. Battery has failed and short circuited the contacts 2. Power supply failure 3. Motherboard could have failed in style. 4. Power contacts for the AC adapter are damaged.
Jun 15, 2008 | Toshiba Tecra M2-S730 Notebook
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Compaq Presario SR1000T (568657) PC Desktop Logo
1,660 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
