Question about Nikon COOLPIX P80 Digital Camera
Nikon coolpix s5100 won't turn on - Nikon COOLPIX P80 Digital Camera
BillB-SA
  • 2761 Answers
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
  • 102366 Answers
SOURCE: Cannot turn OFF self timer mode on Nikon coolpix 8400.
Press the self-timer button (marked with a one-handed clock) once for ten-second delay, twice for three-second delay, three times to cancel timer.
Posted on Dec 12, 2010
dddriver
  • 107 Answers
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Posted on Jun 13, 2011
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
t00nz
  • 4738 Answers
SOURCE: New S5100 Nikon coolpix 12 mpx lens error . It
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Posted on Jun 26, 2011
rajdeepdutta
  • 2517 Answers
SOURCE: my nikon coolpix 5700 will not turn on, i have bought new battery for it and it just won't turn on. what do i do?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean , not rusted& the battery connector pin are not bend or broken. After that insert thefully charged battery and try to turn on. If its not turn on then its confirmthe camera internal power supply unit is faulty. For few reason this problemstarted.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
After visual checking by the technician is possible to say which part isfaulty.
For the confirmation you need to visit a camera repair store. With outvisual survey technician can't confirm you which one of them is faulty. Thankyou.
Posted on Dec 04, 2011
Nikon coolpix says "battery exhausted" and now won't turn on. I just got this camera not even a year ago
Try using a cloth with alcohol and wipe battery terminals and insert a new battery may help give us a clue to go to another step.
thnks
Jun 26, 2013 | Nikon COOLPIX S5100 Digital Camera
Nikon S5100 not getting detected in Windows XP Home Edition. Have installed latest version of View NX2 from Nikon site. Works well with Win 7.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
If you insist on using the USB connection, does Nikon Transfer recognize the camera?
Jul 26, 2011 | Nikon COOLPIX S5100 Digital Camera
New S5100 Nikon coolpix 12 mpx lens error . It opens then closes immediately and says lens error on screen . what to do??
Jun 22, 2011 | Nikon COOLPIX S5100 Digital Camera
Hi! I have a Nikon Coolpix. I haven't used it in a while. I charged it over night but it won't turn on.
Your batery is dead they don't like long period of staying discharging (If you 100% shure that your Nikon is working) The time of charge dosen't matter.
Jun 02, 2011 | Nikon Coolpix S210 Digital Camera
I have purchased a Nikon Coolpix S5100 I am unable to obtain a user manual.
You can download a PDF manual from
http://support.nikonusa.com/app/answers/detail/a_id/17001
Jan 23, 2011 | Nikon COOLPIX S5100 Digital Camera
Here i want install nikon coolpix s5100 driver. still not working my CD driver. so i have to download from google. so how can i.?
clear the softwares and drivers you install for your camera,
put in your camera cd
right click on my computer
properties
hardware
Device manager
connect your camera
you will see a new hardware in your device manager
right click on it
click on update driver
then next
then click browse
then select the folder where driver is.
then ok
then it will install
then install you cd software..
thnk you
Jan 12, 2011 | Nikon COOLPIX S5100 Digital Camera
Need a manual
Downloadable pdf versions of the manual for S5100 are here:-
http://support.nikonusa.com/app/answers/detail/a_id/17001/~/user%27s-manual---coolpix-s5100---guide-to-digital-photography
Dec 11, 2010 | Nikon COOLPIX S5100 Digital Camera
Nikon COOLPIX P80 Digital Camera Logo
272 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
