Question about Intel D845GEBV2 Motherboard
I have set a password and now cannot access my laptop.
I cannot access the laptop how can I override it.
  • zwillsue Jan 14, 2009
    The problem was a vista problem and I have had to get a recovery disc from Toshiba.
  • Anonymous Feb 21, 2009
    I set a password to my account but know I can not access and I am the administrative
    Novelist:
  • 180 Answers
Unfortunately, the only 2 ways to do this is by reinstalling the OS or using a password recovery software. I have no recommendation for what works best in the latter but to prevent it from happening again, set up 2 accounts with admin privileges. You may forget one but will probably not forget both.
Keep in mind that reinstalling the OS will wipe out everything you have on the drive now. If you happen to have a separate partition for recovery, use that. There is a chance it will refresh the OS and not wipe out the files but I can make no guarantee unless I was at your system and saw the options it gives you. The good news is that it'll tell you if that is the case prior to beginning.
Please rate this tip accordingly and thanks for using fixya.com.
Posted on Jan 11, 2009
Override operating system password win7x64
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 04, 2013 | Computers & Internet
Override password for lenovo g780 laptop
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Feb 25, 2013 | Lenovo G780 21829TU Dark Brown 3rd...
Problems with Acer laptop running XP, can only get wirless access if there is no wireless password
Chances are that it is still remembering an old password somewhere in the properties... dig through the options an properties to see if there is a place to enter a password that may be overriding the one you are entering when you try to connect.
I know it sounds wrong, but I've run into this before on Windows 7 laptops and have found a previous password embedded in the properties that (once the correct password is entered there) solves the problem.
Nov 01, 2017 | D-Link Wireless N 150 Home Router
Only one device can access the wireless router.
I have the same one try IE 192.168.1.1
that's the home page for linksys
Jan 30, 2012 | Linksys Wireless-G Broadband Router
How to override user password
You can change or remove a user password provided you can login as an administrator. IF NOT then -
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jun 23, 2011 | Toshiba Satellite X205 Notebook
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
How do i change bios settings on a laptop that wont let me passed the hdd password
BIOS passwords on a laptop would be especially tricky to override, especially on a laptop, you will have to take the laptop to a service provider for the specified laptop brand, and have them wipe/replace the chip that contains the password. Hope this helps.
Mar 16, 2011 | Computers & Internet
How do i override the password on my medion notebook laptop?
I assume you are referring to a system (hardware) password that you are challenged for when powering up the laptop, not the operating system password. You can just reinstalll the O/S into another folder to get access to the system and all the data files ...
Two types of system passwords exist;
1 type is the password stored in an area of the mainboard that is called CMOS (Complementary Metal-Oxide Semiconductor) a completely fancy way of saying an area whoes data is kept alive by a battery. You need to know if your model laptop uses a CMOS battery and how you can disconnect it. Go to the manufactures website at: http://www.medion.co.uk/ . If you can pull the battery for 30 minutes or so, then you may erase the password.
2 If you have a system that writes this password to a non-destructive area of the systems memeory in order to prevent data theft, you have a more difficult time removing the password. Some Lenovo systems must swap out the main board. the password cannot be accessed. Try the battery if you can, else Google medion laptop hacks
Oct 13, 2009 | Medion md40298 Notebook
Intel D845GEBV2 Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
