Question about Belkin Computers & Internet
Belkin (F5D8233-4v3) have internet signal, no wireless signal going out
  • 7,627 Answers
Unplug wireless, wait 30 seconds, plug in. If that fails, reset wireless to default settings by pushing and holding the reset button for 30 seconds.
Posted on Dec 03, 2012
bee2busy
  • 51 Answers
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Posted on Feb 23, 2008
  • 66 Answers
SOURCE: losing internet connection
Set your "rekey time/time till rekey" to a longer interval.
Posted on Jan 18, 2009
  • 244 Answers
SOURCE: have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Posted on Jun 28, 2009
  • 16 Answers
SOURCE: We got a Belkin wireless. Plugged into computer
Disconnect The Verizon,Turn On the Wireless Zero Configuration(Means:turn on the card switch)
Posted on Nov 28, 2009
govinda123
  • 2260 Answers
SOURCE: i have cricket broadband wireless
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Posted on Dec 04, 2009
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I, i am now connected to the internet with my wireless router (Belkin f7d1401 v1) but only via cable i can not via wireless. i have also digited 192.168.2.1 but now i dont know going further
You must login to the router and setup the wireless. Make sure you turn the WIFI broadcast on (enable it) so you can actually have wifi signal.
Dec 12, 2010 | Belkin Basic Wireless Router
I recently restored my Compaq Presario V2000 back to windows xp (it was vista before). Now, I cannot connect to the internet. The laptop picks up the signal and the icon on the bottom right says that...
A Belkin router doesn't usually force the utilities page on you. I would advise checking your start page - you might have set it to your router's homepage by accident.
Aug 19, 2010 | Belkin N1 Wireless-N Wireless Router
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
I think this can help you quick....
1. first connect all wire and adaptor properly....
2. open admin page of router from broswer
then click on this link. How to Setup Belkin router Install Belkin Wireless router
it seems may help you,
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Wireless signal is not lighting up and not getting a signal on my laptop, so I am unable to get on the internet
type 192.168.2.1 in Internet explorer and login to the router setup page..if it asks for a password leave it blank and click submit..on the left side of the page you can see an option called wireless.. below that "channel and ssid"...click on that and go and check whether the wireless mode is "on"...in belkin routers the wireless light willnot litup if the wireless switch in laptop is not turned on...so make sure the wireless switch in the laptop is turned on....
try this it ll work... and dont make any other changes in router setup page....
Mar 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Inttalled belkin wireless adaptor, says strength is good, but not valid ip
the work of a belkin adapter is to receive the wireless signal in and around the adapter when pluged into computer
if ur able to see the wireless network then ur adapter is working fine
check the ip as
start>control panel>network connection>rite click on wireless network>click properties>choose internet protocol tcp/ip (highlight it and click on properties) then "obtain ip address has to be checked"
then cllick OK and try going online --- u must access the internet
Feb 20, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Nov 27, 2009 | Belkin (F5D5231-4) Router
Connecting to the internet
  1. Start Menu
  2. Run
  3. cmd
  4. Ipconfig and check if your IP starts with 192.168... if so check the gatway if not you have to configure the router so it can give you an IP address
Jun 23, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin Wireless router loses light display
I would call Belkin, sounds like a faulty router.
How long have you had it? And what made and model is the router?
Oct 19, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
