Question about Samsung RF267AEBP
Whirlpool refrigerator model number ed25pexhw01 ice chute door wont close
3 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Icemaker will not disppense ice on my Samsung RS2534ww
SOUNDS TO ME THE TRANSPORT AUGER MOTOR NEEDS REPLACEMENT. JUST MAKE SURE THAT ON THE CONTROL PANEL, THE CHILD INTERLOCK IS NOT ON WHICH STOPS ICE DISPENSING OPERATION. JUST DONE ONE NOW WITH THE EXACT FAULT.
Posted on Aug 17, 2007
chikabrookly
It could be interlocking switch that detects when the door is open. If the switch is broken it won't turn the ice dispenser on.
Posted on Mar 29, 2016
GE Model PSIC3RGXBV. Inside freezer at top of ice chute, frost builds up. Returns after wiping. Happens on Humid and non-humid days. Empty nesters so doors are closed quickly. All vents inside clear.
the model number didn't come up,but if you have an air leak most likely it's gonna be the ice chute door itself not fully closing,you can get paper towels,and stuff them into the chute hole for a couple of days to see if that's the problem,another thing is open the door and put a light in front of the chute door and look down the hole,if you see light then the door isn't sealing or check the door gasket for any tears
Nov 01, 2017 | GE Refrigerators
Whirlpool gold freezer getting freezer burn?
What is the model number Comernews? Thanks Sea Breeze
Is the ice chute door closing all the way?
Dec 10, 2012 | Refrigerators
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
What is the part called (the little flap that closes after Ice comes throught the dispencer?
it's called an "ice chute door". Look on sears.com, select "Parts Direct", another page will come up, enter your model number of your frig, then enter, wait a few then your model info will pop up, select either the freezer door or if it has "Ice & Water dispencer" select it, wait for another page to come up, then look thru diagram for part you are looking for, then scroll down to that part number and you will be able to see actual mfg part number. There should be a "Ice Chute Repair Kit" listed as that is how they come. Search internet for best price.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Spring and Mechanism Delay fell out of ice dispenser
This is common, take your model number and go to the appliance parts store and order a ice chute dispenser repair kit.
Dec 25, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Nov 21, 2008 | Whirlpool Refrigerators
Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Jul 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Samsung RF267AEBP Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
