Question about Lomanco Whirlybird Turbine Ventilator
How do you adjust a whirlybird roof ventilator
New whirlybirds installed with a new roof, but do not turn consistently. My previous ones turned all of the time, as do my neighbors all around me...and many have new whirlybirds. Is there an adjustment that can be made, or is there an installation problem? My roofer is seemingly playing ignorant about a solution. Thanks for your help
Sunroof will not close. Was working fine earlier today
The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened or closed by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The soft-stop function is controlled by the roof opening panel motor/module. The roof opening panel has 3 modes of operation, manual mode, express open and tilt. The express open feature is activated when the switch is pressed momentarily. The tilt feature is activated when the tilt switch is depressed. These functions are controlled by the roof opening panel motor/module.
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel water trough
  • Roof opening panel rear trough guides
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Smart junction box (SJB) circuit breaker 47 (30A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel switch
  • The roof opening panel does not open or close - one direction only
  • Circuitry
  • Roof opening panel motor assembly
  • Go To Pinpoint Test E .
PINPOINT TEST E: THE ROOF OPENING PANEL DOES NOT OPEN OR CLOSE Test Step Result / Action to Take E1 CHECK THE ROOF OPENING PANEL LIFTER ASSEMBLIES FOR OBSTRUCTIONS OR DAMAGE
  • Check the roof opening panel lifter assemblies for obstructions and damage.
  • Are the roof opening panel lifter assemblies OK?
Yes
GO to E2 .
No
REMOVE all obstructions and REPAIR any damage. If lifter assemblies cannot be repaired, INSTALL a new roof opening panel frame. REFER to Roof Opening Panel Frame in this section. TEST the system for normal operation. E2 CHECK THE ROOF OPENING PANEL WATER TROUGH AND REAR TROUGH GUIDES
  • Check the water roof opening panel water trough and rear trough guides for any loose obstructions.
  • Are the roof opening panel water trough and rear trough guides installed securely and free from obstructions?
Yes
GO to E3 .
No
REMOVE all obstructions from the roof opening panel water trough and install securely. SECURE the rear trough guides or INSTALL new roof opening panel rear trough guides if damaged. REFER to Roof Opening Panel Rear Trough Guide in this section. TEST the system for normal operation. E3 VERIFY THE ROOF OPENING PANEL ADJUSTMENT
  • Verify the roof opening panel is adjusted correctly.
  • Is the roof opening panel adjusted correctly?
Yes
GO to E4 .
No
ADJUST the roof opening panel. REFER to Roof Opening Panel Alignment - Horizontal Adjustment and Roof Opening Panel Alignment - Height Adjustment in this section. TEST the system for normal operation. E4 CHECK THE ROOF OPENING PANEL MOTOR/MODULE FOR INITIALIZATION
    NOTE: The roof opening panel motor initialization procedure must be done when repairs are carried out on any part of the roof opening panel assembly, including whenever the roof opening panel motor/module has been removed from the roof opening panel assembly, a new roof opening panel motor/module has been installed or when a new roof opening panel assembly has been installed. Refer to Roof Opening Panel Motor Initialization in this section.
  • Carry out the Roof Opening Panel Motor Initialization procedure. Refer to Roof Opening Panel Motor Initialization in this section.
  • If the concern still present?
Yes
GO to E5 .
No
The system is operating correctly. The roof opening panel motor/module was uninitialized. E5 CHECK THE POWER WINDOWS
  • Key in ON position.
  • Verify the power windows operate.
  • Do the power windows operate?
Yes
GO to E6 .
No
REFER to Section 501-11 to diagnose the accessory delay relay circuit. E6 CHECK THE ROOF OPENING PANEL SWITCH
  • Carry out the roof opening panel switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the roof opening panel switch pass the component test?
Yes
GO to E7 .
No
INSTALL a new roof opening panel switch. TEST the system for normal operation. E7 CHECK CIRCUIT CBP47 (GN/BU) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Roof Opening Panel Motor/Module C922.
  • Measure the voltage between roof opening panel motor/module C922-4, circuit CBP47 (GN/BU), harness side and ground.
  • Is the voltage greater than 9 volts but less than 16 volts?
Yes
GO to E8 .
No
VERIFY the smart junction box (SJB) circuit breaker 47 (30A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. E8 CHECK CIRCUIT GD143 (BK/VT) FOR AN OPEN
  • Measure the resistance between roof opening panel motor/module C922-3, circuit GD143 (BK/VT), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to E9 .
No
REPAIR the circuit. TEST the system for normal operation. E9 CHECK CIRCUITS CPR37 (YE/GY), CPR39 (VT/WH) AND CPR40 (YE/OG) FOR AN OPEN
  • Disconnect: Roof Opening Panel Switch C930.
  • Measure the resistance between the roof opening panel motor/module C922-1, circuit CPR40 (YE/OG), harness side and roof opening panel switch C930-8, circuit CPR40 (YE/OG), harness side. Measure the resistance between roof opening panel motor/module C922-2, circuit CPR39 (VT/WH), harness side and roof opening panel switch C930-11, circuit CPR39 (VT/WH), harness side. Measure the resistance between roof opening panel motor/module C922-5, circuit CPR37 (YE/GY), harness side and roof opening panel switch C930-14, circuit CPR37 (YE/GY), harness side.
  • Are the resistances less than 5 ohms?
Yes
GO to E10 .
No
REPAIR the circuit. TEST the system for normal operation. E10 CHECK FOR CORRECT ROOF OPENING PANEL MOTOR/MODULE OPERATION
  • Disconnect the roof opening panel motor/module connectors.
  • Check for:
    • corrosion.
    • pushed-out pins.
  • Connect all roof opening panel motor/module connectors and make sure they seat correctly.
  • Operate the system and verify that the concern is still present.
  • Is the concern still present?
Yes
CHECK the jumper harness between the vehicle harness and the roof opening panel for open or shorted circuits. If the jumper harness is not OK, INSTALL a new jumper harness between the vehicle harness to the roof opening panel motor/module. Otherwise, INSTALL a new roof opening panel module/motor. REFER to Roof Opening Panel Motor in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation.
May 08, 2016 | 2008 Ford Expedition El
I have an Ortho Whirlybird seed spreader. What setting to use for spreading 3 lb/1000 ft of Prozon Weed Beater?
I too have been going crazy trying to find instructions for this seed spreader. Go to Ortho Products online and select chat. Tell the agent the UPC code for it, which is: 71549-08450. They can then email you the one-page instruction sheet for it. Otherwise try this site where I uploaded it: http://pdfcast.org/pdf/whirlybird-spreader
Jun 22, 2012 | Bonide """bonide"" prozone weed beater"
How to install my new dvd drive
Hi
Turn the machine off.
Remove the previous drive.
Take the new one and fit it just like the previous one.
Turn on your machine.
The machine will recognize new hardware and the installation wizard will take you through the installation process.
Feb 29, 2012 | Sony VAIO PCV-RS710G PC Desktop
Fully charged will not turn on or reset unit is not damaged had been working fine. turned it off and now nothing.GO 2535 WTE
Restoring your Favorites and personal settingsIf you reset factory settings or update your map you can restore your favorites from a device Backup.Your Favorites are located inside your map folder, stored in the file MapSettings.cfg. This file consists of the following:Home addressRecent destinations Favorites Connect your Tom tom to the computer and select the option below that best fits your situation:If you are going to be installing a new map to your TomTom or you plan to perform a factory (hard) reset on your device, choose Backup and restore Favorites from your TomTom. If you have already installed a new map or performed a factory (hard) reset, choose Restore your Favorites from a previous backup.Restoring Favorites from a previous backup can only be done if you have previously performed a backup of your Tom Tom device.
Aug 18, 2011 | Tomtom GPS
My car metal roof is making noises like asif it is stuck somewhere and its not closing properly ? any ideas
When the roof is closing and it stops does it make a juddering noise or is it quiet. First of all open the roof fully and check that the guide rails on either side are free of dirt, use a paint brush and WD40 and use plenty of cloths to prevent dirt splashing every where. I have a '96 E-class but I think the roof mechanism is very similar. If the roof make a juddering noise this is not so good. The motor is located above the left rear wheel in the boot. The mechanism consists of a toothed cable driven by the motor through a pipe guide to the rear of the roof panel. You will have to disassemble this motor and gain access to its drive gear in order to clean it of metal shavings/debris and to re-grease it. It is a very frustrating job and one that may wish to leave to the Mercedes experts because even having rebuilt the motor there is a real knack to adjusting it. If the roof is just coming to a stop and not making any noise then you in luck. Locate the motor and the large central nut on top is the clutch adjuster. Tighten it by 1/6th of turn and try to close the roof again. Keep adjusting the clutch tighter until the roof closes. If you hear juddering noises, immediately slacken the nut off and the above notes will apply.
Apr 26, 2011 | 1993 Mercedes-Benz S-Class
Its not drying the clothes and is taking longer to dry. is there a way to reset?
Dryer Repair. In most cases the problem lies in the vent. Your vent may have partially blocked with lint. The first step is to have vent cleaned out by a vent cleaning company or else buy the "whirlybird" drill attachment and do it yourself. Of course, this is assuming you are getting heat inside the drum. Hope this helps,
Sep 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Heater not consistantly turning on
This is an interesting problem. In the beginning of your statement you say that the "heater" does not turn on consistantly. My first couple of thoughts are, 1. What is your fuel source? 2. How is the furnace vented? (chimney, sidewall) With these questions answered we might be able to get to the bottom of the issue. But just for giggles lets continue to make observations. A "ventilation fan" does not really give enough information. There is a "powerventer" which allows you to vent an appliance out the side of a house. There are booster fans, which are sometimes installed in long lengths of "vent" pipes to help the chimney maintain a proper draft, and on gas appliances (newer) there is a inducer motor, which pushes the gases out of the residence. The way that the powerventer is wired is in a way that will not allow the burner to fire unless it first proves that venter is creating a draft. Booster fans usually are just wired in parallel with the burner circuit, and will run anytime there is a call for heat. Inducer motors (on gas furnaces only) will not cause this issue. With all this being said, I would find it highly unlikely that the problem is/was both in the board and the draft. If in fact you are pulling such a strong draft that you are "sucking" the flame out, then I don't think you need the "ventilation" fan. Hope this helps
Jan 21, 2010 | Bryant 463AAC005BA Air Conditioner
Wet ceilings
You must conact your roofer and complain... COMPLAIN.. it sounds like you have a leak and the installers have allowed moistere to get under the roofing materials...!!!
Basically water expands when it freezes (ice cube tray.. over filled ) so if there's any kind of leak the water penetrates.. feezes allowing it to migrate up under the materials and then as the warm air from inside the attic causes the ice to then melt. I'd call and find out what the deal is.. especially if this has been going on SINCE the new roof was installed....
good luck
Oct 26, 2008 | Measuring Tools & Sensors
Lomanco Whirlybird Turbine Ventilator Logo
52 people viewed this question
Top Lomanco Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lomanco Plumbing Expert? Answer questions, earn points and help others
