Question about KitchenAid KEBC107 Electric Single Oven
Kitchen aid single wall oven 1998 kebs278d ?
Cleaned oven ,quit cleaning displayed error code F5EO [door latch switch ?] door is latched tried shutting off power but willnot reset. how does one get door to open unit is screwed into base cab.also where is door latch switch located.any answers would be appreciated
4 Suggested Answers
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 1314 Answers
SOURCE: kitchen aid wall oven kebs177dssp
call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
Posted on Dec 29, 2007
jumptrout51
  • 3361 Answers
SOURCE: need instructions on how to remove microwave to fix oven latch...
In the cabinet above the microwave there wil be 2 to 4 screws that have to be removed.
You need 2 people to remove this unit.
Posted on Feb 25, 2009
taran_2005
  • 10515 Answers
SOURCE: Kitchen Aid Wall Oven KEMS308SSS - Display Panel
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 22, 2010
After heating up oven displays f-45 error code then shuts down
Bosch error F45
Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. If F45 persists, replace power board.
press the helpful button, and check link below
Appliance Fault Codes AppliancePartsPros com
Jan 19, 2016 | Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
F5eo code and door lactch is out?
Error code F5-E0 means a Door Latch failure and is displayed due to malfunction of door latch-switch assembly.
To start, I suggest check the door latch switch, if this is good, then recommended replacement of door latch-switch mechanism.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose.
Oct 22, 2011 | KitchenAid KEBC107 Electric Single Oven
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
Getting error code EO - F5. What's the fix???
Hello & Welcome to FixYa
Error code F5-E0 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Whirlpool RBS275PD Electric Single Oven
Error code F5EO
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
Dec 19, 2010 | KitchenAid KEBC107 Electric Single Oven
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Trying to find out how to lock the door on the whirlpool designer
The door latch mechanism is defective. It is self-latching.
The door latch switch must be replaced.
Feb 21, 2009 | Whirlpool RBS275PD Electric Single Oven
KitchenAid KEBC107 Electric Single Oven Logo
102 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
