Faulty WI 101 Washing maching
I can pursuade it to work! I have had it for 5 years... I try to program it, it thinks about starting, and then the knob just clicks round for ever, until I turn it off. It is making noises like it wants to work, but nothing is happening.
  • Washing Mach... Master
  • 3,463 Answers
If it has a reset point, usually a black dot on selector switch dial then set it there and let it drain for a minute, switch off, reselect prog and switch on if no better then the main pcb is faulty, and will have to be replaced.
If no reset, then main pcb is faulty regardless.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Timer knob does not stay out
This means that the program controller unit is faulty and is not working. You can use a multimeter to check the voltage to the inlet valve and also check if the water level sensor is working to allow the program to start. If so the controller unit is faulty.
Mar 12, 2012 | Kenmore Washing Machines
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
I pushed the button after the washing cycle had start for the purpose of stopping the cycle so that the clothing can soak before washing. When I returned about half an hour later, I pushed the button to...
I am taking this as a machine with a timer knob. If so, you may have to advance the timer manually to get it to go. You may have stumbled onto a slightly dead spot on the timer. I think I would just leave the lid up next time. That will stop everything and give you the soak time you so desire.
Jun 22, 2010 | GE EWA5600GWW Top Load Washer
Whirlpool washing machine, works when turn manually, but not auto
that would be your timer. Yes, it would have to be replaced and it isn't cheap depending on the year and if it is digital or not.
Jul 03, 2009 | Washing Machines
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
I press the start button and it says error.
Had the same symptoms. Tried unplugging power for 5 minutes, no change. Did the Select+options button for 5 seconds, the column of lights flashed once, and then I hit the Start, the door locked, clean clothes followed shortly thereafter :)
Jun 12, 2006 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
