Question about Garden
What gearbox oil do you use? - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Gearbox? no gearbox on a 2 cycle chainsaw
Posted on Dec 07, 2012
Does a 2011 caddyTDi250 1.6 ltr need the gearbox oil changed when the vehicle has its regular service?its 5 speed manual gearbox,and is there a filter to be changed?
No but check with the dealer or your service/owner manual for the manufacturer recommended gearbox oil change periods.
There is no filter on the manual gearbox .
Whatever the manufacturer recommended period is for a gearbox oil change, change the gearbox oil twice as frequently as recommended to maintain it in good condition. If, for example, a change every 50000 miles is stipulated then do it every 25000 or so.
Nov 02, 2015 | Cars & Trucks
Where do I open the gearbox to put in more oil?
the oil filler and level indicator are usually at the same point which is usually on the side of the gearbox. removethe plug, fill the gear box with the correct oil until the oil starts to pour back out of the plug hole. then replace the plug. (basically)
Mar 02, 2015 | Opel Cars & Trucks
Post hole digger gearbox oil leak
If the instructions do not give you an answer to your question and you can't find any information from the manufacture I would proceed as follows. The oil coming out of the breather is due to the splashing of the oil and the heating of the parts as they work building up pressure. I would tend to believe that as long as there is some coming out there is enough oil to take care of the gearbox.
If there is a separate plug to remove to add oil to the gearbox I would use that as my fill level. I hope this helps.
May 11, 2014 | Garden
The 4speed triptronic gearbox in my mitsubishi verada 2006model keeps jumping in and out of gears
Check gearbox oil.
Replace gearbox oil and gearbox oil filter, then retry.
Nov 07, 2012 | Cars & Trucks
How do I put gearbox fluid in ? Where is the level glass? I have a 1997 mitsubishi magna
Gearboxes usually have no oil dipstick / looking glass. On the side of the gearbox there's a bolt with (brass) washer. This is where the gearbox oil goes. To check the level is to stick one finger in downwards, when there's no oil at this level its usually too low.
On the bottom of the gearbox there's a similar bolt with washer to drain the old oil. The bolt can be magnetic - and can look a bit like a mushroom. Tiny particles from the gears stick on there - this is normal. Large bits of metal can be a cause for concern.
Always use the specified gearbox oil - wrong oil makes changing gears hard.
Jul 05, 2011 | Mitsubishi Galant Cars & Trucks
My gear stick keeps jumping when in gear.
Hi sheila? this is normally caused by lack of oil in the gearbox. make sure the gearbox oil level is ok before doing any thing els. In the fron of the gearbox there should be a plastic lead which can be unscrewed to inspect the oil level. the oil level should be level with the base of the hole. If oil comes out when you unscrew the lead that's ok. If the oil level is ok then the gearbox may be worn out.
May 21, 2011 | Renault 18I Cars & Trucks
Do i need to put gearbox oil in my roadwin aswell as engine oil
Hi the roadwin is a fourstroke engine and the gearbox is 1unit, so the engine oil lubricates the gearbox also, ( no need for gearbox oil)
Regards, paul
Mar 01, 2011 | 2007 Daelim Roadwin
Vz 1600 gearbox leak
The gearbox IS part of the block and the oil is shared between the gearbox and crankcase, so yes, this is motor oil. That little plastic cap is the top of your oil pressure switch/sending unit and there is supposed to be a wire attached to it. This part is relatively inexpensive from the dealer and quite easy to replace.
Mar 26, 2010 | 2004 Suzuki VZ 1600 Marauder
Gearbox oil change
There should be a drain plug either on the bottom of the gearbox or on the side of the gearbox at the bottom. Put in fresh 10w40 motor oil. There will be an oil fill screw either on the left or right side of the gearbox case.
Apr 28, 2009 | 2005 Hyosung GT 250
Gearbox oil
there is no dip stick for the gearbox oil..there is a little rubber cover on a little tube sticking out of the gearbox housing. remove the rubber cap and fill through there.
Nov 29, 2008 | 1997 Honda Prelude
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
