What is the cubic ft in a whirlpool duet w10158202a
  • 7 Answers
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Posted on May 27, 2009
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: no codes on a whirlpool duet ft loaader. can they
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "Fantastic. Like the subtle hint;)... and well deserved."
  • 552 Answers
SOURCE: What is error code f 21 on a whirlpool duet sport
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Posted on Apr 13, 2011
What is the rated capacity for a Whirlpool Duet Sport Washing Model WFW8300SW02 Type 831
Capacity = 3.3 Cu Ft
Whirlpoolcorp.com download manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8300SW0&siteCd=WHRCOM&userType=Consumer#
The breakdown for Whirlpool Serial Numbers is:
1st Alpha Character = Manufacturing Division Code.
2nd Alpha Character = Year Manufactured (See Tables).
1st and 2nd Digit = Week of Year Manufactured.
3rd though 7th Digit = Order of Manufacturing that Week.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
If this was helpful, please rate post
Sep 13, 2014 | Whirlpool duet Washing Machines
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Just want to know cubic feet of the whirlpool ghw9100
The volume capacity of Whirlpool Duet GHW9100 is 3.7 cubic feet. Refer to the specifications below for other details.
Jul 19, 2011 | Whirlpool GHW9100L Front Load Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What are the specs of my washer.cubic ft?
Amperage 15 or 20 amps Depth 31-1/2 in. Height 38 in. Width 27 in. Tub capacity 3.8 cu. ft. Number of cycles 8 Number of speeds 4 Number of temperature selections 3 Bleach dispenser yes Pre-wash/auto soak cycle yes Voltage 120 volts
Apr 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
