Question about Cuisinart Coffee Makers & Espresso Machines
Water in drip tray when reservoir filled cuisinart dcc 3000
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
Same problem . Sent my first machine back (less than 1 year old, you pay shipping and handling both ends) and now after 4 months, same issue. Not sure what to do.
Posted on Feb 17, 2008
SOURCE: Cuisinart Coffe Maker has no power
Talked to Cuisinart tech support today and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults. Worked for me...
Posted on Feb 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DCC-2000 leak
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
  • 85 Answers
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: My coffee maker, Cuisinart dcc 1400 only boils
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
WHY DOES WATER LEAK OUT OF THE BOTTOM OF CUISINART COFFEE MAKER DCC-3000
Usually this is due to over-filling the machine with water or too many beans. Follow directions carefully, limit the total water to the highest mark on the the carafe and the beans to the mark in the grind basket.
Oct 06, 2016 | Cuisinart Coffee Makers & Espresso...
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
My Cuisinart dcc-2600 does not distribute the water.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. This can clog the Percolating tube, resulting in low or slow water circulation.
The calcium can also impact the function of the Heating elements in the percolator tube.
Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
I would repeat this process every month or so if you use your machine daily.
If this does not solve, try contacting cuisinart customer service at 1-800-726-0190
Jun 08, 2012 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
WATER WILL NO LONGER COME FROM RESERVOIR INTO FILTER
This happened to me also. Try filling Reservoir with white vinergar, the tube that brings the water up to the filter might ge clogged with lime residue from your water.
Oct 24, 2010 | Cuisinart DCC-1000 Coffee Maker
I have lost by cleaning manual for my dcc-1200 coffee maker. I need to clean it the light won't shut off. Thanks, Dawn Miller
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
