Question about Samsung PCK520R TV
My tv don't want to turn on
I plugged my television but it won't turn on
    Top Expert:
  • Samsung Master
  • 14,553 Answers
First thing is of course to follow the power cord inside and check the fuse it connects to.
Posted on Dec 04, 2012
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Hannspree tv
1130. Check this code.
Jul 26, 2013 | Televison & Video
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
LCD LE26R7 won't turn on after switching off
This is almost certainly a bad main board and it will almost certainly need to be replaced, not serviced.
I'd google for "LE26R7 main board" - check on eBay as well - but frankly if all you have to do is re-plug the TV in order to watch it I'd probably recommend sticking with that.
I predict there won't be a quick fix to this problem other than replacing the main board.
Don't kill the messenger :-)
bobby @ coppelltvrepair . com
Aug 25, 2012 | Samsung Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Power board for 37pf5521d
hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Feb 19, 2012 | Philips 37PF5521D 37 in. HD-Ready LCD...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
How do i tune the television to a nintendo nes game station
You will need a composite RCA video cable. On the right hand side of the NES, there should be yellow and white RCA connectors, plug the yellow and white ends on the cable into them, then plug in the yellow and white connectors on the other end of the cable into the equivalent connectors on the TV. Turn on your NES. Your TV remote should have a button labeled "Input" or "Video Input" or something like that, press it a few times until you see the game. Enjoy! (Don't forget to blow on the cartridge if the game won't start, LOL)
May 02, 2011 | Televison & Video
I had moved to another state and my tv sat for a couple of months in a temp controlled room. I plugged it in but when I turned the tv on I had a picture for about thirty seconds heard a like a sizzling...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - (sometimes '' garrrr '' like sound comes...that is from EHT )........ in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer.............TUBE IS FINE
Apr 24, 2011 | Samsung Televison & Video
Televison & Video Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
